Gasket Sealer
MichiganBob
Posted
Hi All,
Starting to reassemble my 02RT after installing new clutch and spline lube. About to install new slave cylinder. Should some gasket sealer be used or just put it in dry?
Thanks.
Bob
Posted
Afternoon Bob
I usually install those dry, in fact I cut a small slot in the bottom of the gasket to allow any slight slave leakage to leak out the rear rather than follow the push rod forward & pollute the clutch disk.
