redknight6 Posted August 5, 2012 Posted August 5, 2012 Seem to be having a problem with my cooling fans and not sure they are kicking in all the time, does any one have the electrical diagram of the wiring. it would make it easier to trace. The problem might be a the temperature sender, but have not been able to find the darn thing, if too much of a problem I will put in a switch and by pass the sender.
upflying Posted August 5, 2012 Posted August 5, 2012 Diagrams are here. http://www.bmwmc.net/mc.asp?O=frames FWIW, I have not heard my fan operate either. The bars have to get real high before anything happens. Parade riding for 1/2hr at 3 mph should get it hot enough.
redknight6 Posted August 5, 2012 Author Posted August 5, 2012 Thanks for the link but it would not let me in? I found out that the fans was working when I set the Balance of the Fuel air mix. I burned up my Shark fins a little, Bruce
upflying Posted August 5, 2012 Posted August 5, 2012 Ok, that link is always tricky. I'm not computer literate but the only was i get in is come from a different website and then open police bmw link from it. The website I used is policeone. Open the site and then open the bmw police vehicle link. http://www.policeone.com/
redknight6 Posted August 6, 2012 Author Posted August 6, 2012 Thanks got the info I need to fix or check the problem
