Replacing Injector O-rings
Twinsig
Posted
Going to replace o rings but scared I'll break the injector.
What's the a trick?
Posted
I use a small pick. Its a pointed tool with an S bent in the end. You can also stab the oring to pull it up and get a small screwdriver or another small pick to get it off. Roll it off and roll the new one on. Make sure its not twisted when done. A LITTLE silicone grease or spray will help put them back in.
Posted
Thanks for the input david. I may just cut the old one and use a similar sized socket to install the new o ring and avoid the possibility of breaking the plastic tip/lip of injector.
Posted
Hi Twinsig. I would seriously avoid cutting the O rings. It is all too easy to cut and the damage the sealing face of the O ring groove.
Just use something like a toothepick to stab the o ring material, and then hook it out (again with a soft object). Once the o ring is moving you may be able to squeeze the circumferance of the O ring and it may bulge upwards and you can pick it out from there.
Andy
