side case marker
515PHOTO
Posted
Hi all,
I want to change the 'touring' badge on the side case of the 01 1100rt with the reflector that came on non-rt versions. Is this badge a peel and stick, epoxied or some other way attached? No through bolts/screws apparent. I don't want to break the case cover prying it off if it won't pry off. Anyone removed this?
Posted
It's held on by double sided sticky tape. Use a piece of fishing line to cut through the tape and remove the badge.
Posted
Thanks.
Posted
Or for non fishermen, but orally conciencious....try dental floss.
Andy
