R1100RT clutch switch - at rest position?
szurszewski
szurszewski
Posted
I've had a second clutch switch (if that's the correct term - I'm referring to the switch at the left grip that allows, when working, you to start the bike "in gear" if you have the clutch lever pulled in) fail, and I figured I'd tear it apart and see if I could fix it instead of spending another $40 (beemerboneyard again does not have one in stock).
I suppose my volt meter and I could figure this out, but is the at rest position for the button/switch in or out? I know I could bypass it by twisting the wires together before the switch, but by looking at it, I can't quite tell if pulling the clutch lever pushes the button in (which is my guess) or let's it come out.
Thanks in advance - much appreciated.
josh
Galactic Greyhound
Posted
The internal spring went on mine too - goodness knows how long it was like that! Now part of a regular test routine in case the Neutral Switch ever goes!
The switch is released when the clutch lever is pulled in which causes the switch to operate and complete a ground circuit for the Starter relay coil.
