HELP Bolt alignment after tail in the air.
ltljohn
Posted
I had the tail in the air I am putting it back down but I can not get the bolt holes to line up. The lower ones on the transmission and the ones on the rear frame line up but the ones that go up to the big casting are too far forward. Is there a trick to this?
Posted
Do not tighten until they are all in.
David
Galactic Greyhound
Posted
Probably due to frame/engine sag - try jacking things up a bit to take the weight off until all the bolts are in.
