Cat-Gut
Twinsig
Posted
Anyone out there ever remove cat internals?
Why?
Why not?
Posted
Afternoon Twinsig
Yes I did (gutted) one of my 1150's. Did it all through a small hole in the side of the cat then made a small inner/outer plug to plug the hole.
Reason= the bike was fueled to be non emission compliant so no reason to keep the cat internals.
Basically I wanted to see if it improved exhaust sound or vehicle performance. It did neither,-- made the exhaust a bit louder & slightly raspier but no better sounding & added not one MPH to my top speed.
Posted
I did it on my RT when I found a crack in the cat converter. It did nothing performance wise, nor did it help with fuel mileage. What it did do was make the exhaust a little louder and made it pop and sputter on deceleration. I dealt with it for a while, but ended up replacing it with a stock exhaust I landed cheap on Ebay.
Not worth the time or effort in my opinion.
Posted
I did micro surgery. I cut a hole in the the top of the muffler, removed the cat and tig welded it all back together with 308L. I got the same result as the folks above. I think it sounded better before I did the work.
I like the pop on decel. I hold a little throttle on while coasting sometimes.
It is a heavy little thing.
Would I do it again? dunno. I am glad I don't have that heat under the engine/tranny. I too use a techlusion. (fuel thingy)
Posted
Thanks yall. Those are exactly the answers I was looking for!
Posted
Is that "you" in the avatar photo?
roger 04 rt
Posted
Afternoon Twinsig
That's a clean bike and a clean garage ...
Posted
I agree with what Keith says. I took my exhaust system to a machine shop and had them remove the cat and stitch it back up on my '04RT. I did it because I didn't like all the heat right under the tranny. Would I do it again? Probably not as I don't like the raspy exhaust note and all the popping on deceleration. Wish I could have the cat chamber packed.
Posted
Hi Roger, I think that is D.R.s bike in the pix.
Posted
Absolutely. :grin:
Posted
OoPEZoO: Looks like your medication is working!!
Roger: Not my bike! Mine looks more like a truck. Rough/tough and no need to keep it super clean.
Posted
I took the guts out of a cat, hoping to re-string my tennis racket. Turns out, it ain't what it sounds like. And damned hard to put 'em back in.
(Sorry......I could not resist. The above is a work of fiction, no felines were injured in the making up of this tail....er, tale.
