Lawman Posted December 20, 2005 Share Posted December 20, 2005 Earlier today as it started to rain I began to wonder if my on/off switch and system for my Gerbing jacket liner was suseptible to damage if it gets wet while being used. What's the wisdom of the Board? thx... Link to comment
Ken H. Posted December 20, 2005 Share Posted December 20, 2005 Probably not. In reality it is just a 120v lamp cord switch and is pretty robust and simple inside. It would take a lot of water, like submerged, before you would short it out. I suppose for to avoid long term corrosion of the contacts to wouldn't hurt to shake any water out of it at the end of the day. Link to comment
mmm...pies Posted December 20, 2005 Share Posted December 20, 2005 I assume you mean the temp controller - Gerbing's claims and my experience has been that it will be fine in all weather. See here > http://www.gerbing.com/divmc/tempcontroller/port.html Link to comment
ChuckS Posted December 20, 2005 Share Posted December 20, 2005 I ride all the time in the rain, and Grebings in made here in the land of rain... I just had to replace a switch. Damm thing only lasted 9 1/2 years! You just can't get good parts that will last any more!! My switch is mounted on my bike... really its no worries! Link to comment
Ken H. Posted December 20, 2005 Share Posted December 20, 2005 I assume you mean the temp controller - Gerbing's claims and my experience has been that it will be fine in all weather. See here > http://www.gerbing.com/divmc/tempcontroller/port.html Well he said "on/off switch" so I assumed he meant the large brown clunky on/off switch Gerbing sells. Regardless I suppose, the on/off switch is pretty tough, and the variable temp controller is designed to be water resistant. Link to comment
Lawman Posted December 20, 2005 Author Share Posted December 20, 2005 Thanks to all....One less thing to worry about...It is a switch only..Hope to upgrade to a thermostat some day..Maybe next Christmas... Link to comment
