Pbrokaw Posted June 4, 2012 Share Posted June 4, 2012 Guys and Gals: Has anyone removed the lock assembly and replaced it With a twist knob to allow use without the key? I have a spare ignition key on a lanyard but I would like to just turn a knob to open,grab water bootle,take a drink,and close it. I use a modular helmet so I can do this " inflight refueling" while riding down the road. Nothing is stored in the box of big value so theft is not worried about. Any ideas??? Thanks Perry Link to comment
dirtrider Posted June 4, 2012 Share Posted June 4, 2012 Afternoon Perry I did just that on my old 1150RT. I removed all but one tumbler from the glove box lock. Then took an old key & ground it's notches so it would not work in the ignition switch (didn't grind on the one that matched the remaining lock tumbler). Then I made a nice little knob on my lathe then used the mill to cut a slot in the bottom of the knob to insert the cut down key. Lacking a mill & a lathe you could use about anything in the shape of a knob then fill the insides with epoxy then imbed the cut off key in it. For a key you could ask your local BMW dealer for an old unwanted key (they probably have a box full that they have no idea what they went to) then re-key your glove box lock with one or two existing tumblers that will allow that key to work. Added: use the deepest notch in the glove box lock key as that will retain the key/knob in the lock better than a shallow one will. Also easier to grind on the shallow notches to disable the key as a valid ign switch key. Link to comment
Jerry Johnston Posted June 5, 2012 Share Posted June 5, 2012 I had a spare key made and then gound the head down to where it fit inside the round hole of a radio (amplifier) knob and filled it with epoxy. If you want a picture I'd be happy to send it or even make one for you if you wanted to send the key to make it out of. Link to comment
