Sidmo Posted June 3, 2012 Share Posted June 3, 2012 About 4 seconds after starting my bike the volume drops on my Zumo 550. Plays fine without the bike running. Only thing different since the last time using it was that I just did the Oilhead Timing Chain Tensioner Upgrade but I don't see how this could have caused the problem. Any ideas? Zumo is connected to Starcom 1. No problems with this for 5 previous years. Thanks Link to comment
Danny caddyshack Noonan Posted June 3, 2012 Share Posted June 3, 2012 If all else fails, you might try a full reset. On the 66x's, hold down one of the corners to get the unit to go back to all of the factory defaults and remove all connections. You might also check for an update on the firmware? Link to comment
FlyingFinn Posted June 3, 2012 Share Posted June 3, 2012 You need to debug which one actually causes the change in volume level, the Zumo or the Starcom unit. Leave everything on the bike, all connected as normal EXCEPT plug a pair of earbuds to the Zumo and listen if volume drops. Also, do both nav and music volume do the same? -- Mikko Link to comment
Sidmo Posted June 3, 2012 Author Share Posted June 3, 2012 Just took a ride and connected to the Zumo and everything is fine so it must be something with the Starcom. Thanks Link to comment
