jora112233 Posted May 19, 2012 Share Posted May 19, 2012 Good morning all. Just fitted a new pair of Avon Storms to the bike. Anyone had any experience of them? £192 a pair. £20 fitting for both tyres to loose wheels at a local tyre garage. Not bad. Also, anyone know what I should be torque the front axle bolt should be? just bloody tight? I've mislaid my manual! Jon Cardiff Link to comment
Jim Moore Posted May 19, 2012 Share Posted May 19, 2012 I have two manuals. They both say 30 nm for the axle bolt and 22 nm for the pinch bolts. One says 40 nm for the brake caliper bolts, the other one says 30 nm. Link to comment
jfremder Posted May 19, 2012 Share Posted May 19, 2012 I have two manuals. They both say 30 nm for the axle bolt and 22 nm for the pinch bolts. One says 40 nm for the brake caliper bolts, the other one says 30 nm. 30nm for front caliper bolts, 40nm for rear Link to comment
OoPEZoO Posted May 19, 2012 Share Posted May 19, 2012 I ran the Storm's for a few tire changes when I first bought my RT. I loved the handling, but I never got more than 6-7k miles out of a set. I even wore one rear to below the wear bars in 4500 miles. That was riding two up with fully packed luggage. Link to comment
Dave Parry Posted May 19, 2012 Share Posted May 19, 2012 I put Storm Ultra's on my R1100RT middle of last year and am very pleased with the handling, I noticed a vast improvement over the B23 Battleaxe's that were on there before, (and they were not that badly worn) I can't say much about the Storm's regards wear characteristics as i've only done a couple of thousand miles on them. Btw, I presume you know the recommended pressures for the Storms? 36psi front, 42psi rear, as advised by Avon technical, Dave. Link to comment
jora112233 Posted May 19, 2012 Author Share Posted May 19, 2012 Thanks Gent's. All fitted. Did have a very scary moment when I thought I may have cross threaded the front axle bolt. Had to take it back out and carefully rethread with the bolt in the vice, but it was fine. Not sure if it was because of where I'd hit the thing out albeit with a tap tap tap... Spotted something just as scary, and I may well get ostracised here for mentioning it, but just running through my service check list, and to my dismay, cant remember ever changing the transmition oil. Plan to do it in the morning, have given the drain plug a squirt with penetratinbg oil, as its siezed up a bit. Thank heavens for over long allen keys! Cant understan how as I've changed the shaft drive oil a few times... Jon Cardiff Link to comment
jora112233 Posted May 19, 2012 Author Share Posted May 19, 2012 n.b. A bit worried about some of the low milege comments. Had around 10k Miles out of my last back battleaxe. Thanks again Jon Cardiff Link to comment
Boffin Posted May 19, 2012 Share Posted May 19, 2012 Just a thought - make sure you can undo the gearbox filler plug before removing the drain... DAMHIK Andy Link to comment
jora112233 Posted May 19, 2012 Author Share Posted May 19, 2012 Thanks Andy - yes did try that first, did read that it's always best to check you can put stuff in, before emptying it. Andy - I'm sure you don;t remember as a boffin you probably deal with hundreds of posts, but just to let you know you did recommend a high ah battery last year. Well the good news is that since changing my commute to a longer trip, the old battery seems to be lasting pretty well. I did however use my new battery to start up a neighbours gpz1100 this morning, thats been stood for 18 months. 4th push of the starter and off it went. Happy days! Jon Link to comment
g_frey Posted May 21, 2012 Share Posted May 21, 2012 The Storms were OK tires but did not last as long as ME 880's. Link to comment
