OU71 Posted December 16, 2005 Share Posted December 16, 2005 I'm considering moving up for all the improvements the 1200RT has, but I also really want a good radio this time. And all I've heard on this site is how crappy the BMW 1200RT radio is. I like to listen to local sports & news as much as music, so I need a car type radio that has good AM/FM reception. Has anyone had good luck with the BMW radio, or has anyone put in an aftermarket one that worked well. Thanks. Link to comment
johnlt Posted December 16, 2005 Share Posted December 16, 2005 I've got the BMW radio in myh 1150RT and am very satisfied with it. I use it for local news on the way to work and back. Works great. I also use the tape adapter on an XM radio that allows me to use all the handlebar controls for volume and changing between radio and XM. Only problem I've had is range and this is normally when I'm on the interstates but I pretty much only use XM on those trips anyway so not a problem. I'd do it again even though they are over-priced. Link to comment
flobti Posted December 17, 2005 Share Posted December 17, 2005 My experience with the RT radio is not good. I got it thinking it would be just like the LT radio, which I found excellent. My AM is virtually unlistenable - FM is a bit better. Wish I had saved the $1500. Link to comment
FIRST_BEEMER Posted December 17, 2005 Share Posted December 17, 2005 I installed a Pioneer AM-FM-XM-CD unit with 100 watt speakers. Works like a charm. Sounds better than the $1500.00 BMW unit. Fits in the clove box the same as the BMW unit. Total cost including the XM modules $340.00 Link to comment
scottcon Posted December 17, 2005 Share Posted December 17, 2005 What was the model number of the aftermarket speakers and did they fit well in the speaker housing on the r1200rt? Did you have to modify anything? I want to do the same thing as my bike did not come with a stereo or prep kit. Thanks in advance. Link to comment
Whip Posted December 17, 2005 Share Posted December 17, 2005 How do you control the volume and station changes????? Larry Link to comment
scottcon Posted December 17, 2005 Share Posted December 17, 2005 I have done some research on radios but need to know which speakers will fit. Alot of stereos made for marine applications come with wired remotes. I plan to stick the unit in the glove box and run the remote over to the left side where the bmw stereo controls go. Do a google search for marine radio/stereo and you will see what I mean. harry Link to comment
FIRST_BEEMER Posted December 18, 2005 Share Posted December 18, 2005 Take the dash apart and you`ll see. Nothing in it to modify. You`ll need to set it up from scratch. Link to comment
scottcon Posted December 18, 2005 Share Posted December 18, 2005 What size speakers? 4"x4" or 3" X 3"? I would like to order everything before taking the dash and tupperware off. Thanks. Link to comment
