JGP Posted May 11, 2012 Share Posted May 11, 2012 Can you please advise how to adjust the throttle cable. It appears under the throttle there is an adjustment device, but how much slack is the right amount? thanks jGP Link to comment
dirtrider Posted May 11, 2012 Share Posted May 11, 2012 Morning jGP What are you trying to accomplish with the adjustment? A full (cable system) adjustment or just the cable at the twist grip? Link to comment
JGP Posted May 11, 2012 Author Share Posted May 11, 2012 Just the throttle grip, thanks jgp Link to comment
dirtrider Posted May 11, 2012 Share Posted May 11, 2012 Afternoon JGP Well, the BMW service manual calls for using their service computer to set that cable slack on the 1200R bike (strange). So if we go to the BMW 1200GS service section that calls for .5mm cable slack. I don't see any reason you can't use the GS setting. Personally I don't like that much cable slack in my twist grip so I set both my GS & RT to just a bit of cable slack (quite a bit less than the .5mm) Link to comment
