Lawman Posted December 15, 2005 Share Posted December 15, 2005 Okay, Here's what I want to do..Anyone know if it will work? I have the Gerbing battery harness on my battery for my heated jacket liner. I have a Wal Mart portable air compressor that's rated for 15 amps with a cigar/cigarette lighter plug on the end of the cord. I want to cut off that plug and put a plug like the one on my Gerbing jacket liner that will plug into the battery harness in the event of a flat..Will it work Okay and can I buy such a plug? thx.. Link to comment
RichEdwards Posted December 15, 2005 Share Posted December 15, 2005 I did this very thing. Just order the plugs from Gerbings. My heated jacket hookup is my tire-inflator hookup and it works fine. Link to comment
Lawman Posted December 15, 2005 Author Share Posted December 15, 2005 Outstanding! Thanks.. Link to comment
FIRST_BEEMER Posted December 16, 2005 Share Posted December 16, 2005 You might need to change the fuse to a 15 or 20 amp to hold the load of the pump. I don`t know what the gerbing fuse rating is. Link to comment
ShovelStrokeEd Posted December 16, 2005 Share Posted December 16, 2005 The Gerbing is fused at 15 amps. I bought a spare glove harness which has 3 of the proper connectors on it and everything I need is wired for that system. Charger, compressor, 3 separate tank bags, and all my running bikes. You can also source the connectors at Radio Shack and, I would imagine, any of the major electronic houses. They are called coaxial power connectors. Link to comment
Ken H. Posted December 16, 2005 Share Posted December 16, 2005 Will it work Okay No problem. In addition to adapting my tire pump as you describe, I also adapted my battery tender to mate to the connector so as not have to fiddle with all that switched acc'y outlet garbage just to charge the battery. I bought the Gerbing Y harness and cut it up to get the connectors I needed to do the above. Link to comment
Lawman Posted December 16, 2005 Author Share Posted December 16, 2005 Thanks! I shall buy the sock and glove wiring and use the connectors to convert my compressor and battery tender to work..Thanks! Link to comment
Jim VonBaden Posted December 17, 2005 Share Posted December 17, 2005 RadioShack has male ends in stock. I got one for my CH compressor for my 12GS. Jim Link to comment
