Bologna Posted April 16, 2012 Share Posted April 16, 2012 The windscreen rubber grommets have done there job and need replacement. Is there a better rubber grommet available or should I just replace them with the BMW grommet and move on! Link to comment
OoPEZoO Posted April 16, 2012 Share Posted April 16, 2012 If you are refering to the grommets that fit between the windshield and the arms. I lost one or two of mine over the years. I replaced them with ones I found at the hardware store plumbing isle.......a REAL hardware store, not a Lowes or Home Depot. Link to comment
rich t Posted April 17, 2012 Share Posted April 17, 2012 If you are refering to the grommets that fit between the windshield and the arms. I lost one or two of mine over the years. I replaced them with ones I found at the hardware store plumbing isle.......a REAL hardware store, not a Lowes or Home Depot. +1 on the plumbing parts. you can get four rubber grommets for about a buck at ace hardware. Take a bolt in with you and go for a tight fit. Grommets that fall off when you are installing your windshield want to fall down into the fairing. Link to comment
Bologna Posted April 17, 2012 Author Share Posted April 17, 2012 If you are refering to the grommets that fit between the windshield and the arms. I lost one or two of mine over the years. I replaced them with ones I found at the hardware store plumbing isle.......a REAL hardware store, not a Lowes or Home Depot. +1 on the plumbing parts. you can get four rubber grommets for about a buck at ace hardware. Take a bolt in with you and go for a tight fit. Grommets that fall off when you are installing your windshield want to fall down into the fairing. Ace Is The Place!! Thanks.... Link to comment
