Helmet lock for R1150RT
MotorcycleWriter
Under the seat on both sides is a little half-loop hook intended to be a helmet lock. All you need is a length of wire cable about 6inches long with a loop on each end, which passes through the helmet.
I believe that the early RTs came with the wire in the toolkit but it was dropped early on.
I got two lengthe made up at a yaght chandler.
Andy
I dislike the under seat lock system, as my back seat is usually full of...well stuff! I use a big carabiner over the back of the luggage rack to hold the helmet by its d-ring when I get off the bike. For security, I have several coated bike cables and a matching set of master locks (same locks on wife's bike). I can run one through the chin bar of the helmet, and through the sleeve of my jacket to lock both on. Takes a few seconds. I really like to hang the helmet so I don't see it bouncing across the parking lot during a high wind.
