smootz Posted February 20, 2012 Share Posted February 20, 2012 Hey Guys, I'm back. It has been quite a while since I visited the forum. I lost the clutch in the RT a couple years back and have been riding another brand (forgive me please) The bike was disassembled a long while back. I have finally forgiven it and am ready to put it back on the road. It is a 2000 RT that I purchased new. It has 128K on the ODO. The clutch began to slip in high gear and I discovered that a bad rear tranny seal allowed oil to follow the push rod to the clutch plate. I have performed periodic maintenance on an anal scale. Shifting is smooth and the drain plug has always been clean. I can pull and replace all of the tranny seals without cracking the case. Does "if it ain't broke don't fix it" apply or should I pull it apart for inspection? Also I may need advise for orienting the clutch/pressure assembly on the flywheel. I havn't looked yet but there is a chance that my reference marks will be illegible after all this time. I will study the manual before attempting this but any advise would be appreciated. I have missed the Beemer. I want it back. Thanks, SCOTTIE Link to comment
texasaggie97 Posted February 20, 2012 Share Posted February 20, 2012 Welcome back Scotty. Please continue to keep us up to speed on the bikes progress. I was gone for a few years and I am back and looking for a new bike. Hopfully I will be able to get back on the road soon. Link to comment
realshelby Posted February 20, 2012 Share Posted February 20, 2012 I have performed periodic maintenance on an anal scale. Shifting is smooth and the drain plug has always been clean. I can pull and replace all of the tranny seals without cracking the case. Does "if it ain't broke don't fix it" apply or should I pull it apart for inspection? Thanks, SCOTTIE Scottie, I had to the same thing happen to my RT. I simply replaced the rear seal that caused the problem. On the '04 you don't have to pull the case apart to replace that seal. The other seals I cannot say for sure. I wouldn't split the case unless I just HAD to. Link to comment
4wheeldog Posted February 20, 2012 Share Posted February 20, 2012 I would see no reason to open the tranny when the only failure was a seal. The earlier (pre 97?) 1100 trannies were somewhat failure prone, but by the time they built yours, they were relatively bullet proof. I hope you took lots of pictures way back when you did the teardown. Link to comment
Selden Posted February 20, 2012 Share Posted February 20, 2012 Also I may need advise for orienting the clutch/pressure assembly on the flywheel. I havn't looked yet but there is a chance that my reference marks will be illegible after all this time. I will study the manual before attempting this but any advise would be appreciated. If you have a digital camera, take pictures of the clutch components, with various lighting. Then, transfer them to a computer, and experiment with changing contrast, brightness, and hue. You should find some combination that reveals details that are otherwise difficult to see. Link to comment
smootz Posted February 20, 2012 Author Share Posted February 20, 2012 I did take some pics, made notes, and marked stuff. It's just been so long I hope I can decipher it all. My 55 year old brain isn't as sharp as it once was. I was really hoping for some factory reference marks. I certainly don't want to do this twice. I feel better about just replacing seals now. Thanks for the info about the pre 97's. SCOTTIE Link to comment
Selden Posted February 20, 2012 Share Posted February 20, 2012 I found fain factory marks on the clutch components of my 1999 RT @ 97,000 miles. If I remember right, I cleaned the parts with isopropyl alcohol, then took pictures, and used digital image manipulation to confirm them. Link to comment
