KDeline Posted February 15, 2012 Share Posted February 15, 2012 It has been discussed, can not find the link. Anybody have it? For a 98 R1100RT. ABS faults while driving, about 3 times in the last month. Resets with startup. Link to comment
DonW Posted February 15, 2012 Share Posted February 15, 2012 Hi KD- try the link below. good luck- Don http://www.largiader.com/abs/absfault.html Link to comment
KDeline Posted February 15, 2012 Author Share Posted February 15, 2012 Thanks, fast response. Well if I am doing this right, I am reading from the middle pin on the ABS plug that is not pluged into anything, and the meter is reading a steady 11 volts. I assume there is no fault stored? Link to comment
Solo6 Posted February 15, 2012 Share Posted February 15, 2012 If the faults come when you use the brakes, then reset when the ignition switch is cycled, it sounds like you're about due to bleed your brake systems. Link to comment
Galactic Greyhound Posted February 15, 2012 Share Posted February 15, 2012 Thanks, fast response. Well if I am doing this right, I am reading from the middle pin on the ABS plug that is not pluged into anything, and the meter is reading a steady 11 volts. I assume there is no fault stored? Correct. At ignition 'On' (bike not started) the middle pin in the flat 3-pin diagnostic plug will show a steady 10 volts indicating 'No fault present'. The voltage will pulse if there is a stored fault code and the number of pulses indicates the Fault Code. All of the Fault Codes except Code 5 (Low Battery) appear to be 'latching' i.e. the Fault Code is held in the ABS Memory until the ABS is 'Reset' - clearing the actual fault does not clear the stored Fault Code until the 'Reset' procedure is performed. If you have an ABS condition (alternating top & bottom ABS lights?) coming on when the bike is running the fault should be stored unless it is a Code 5. A Code 5 resets automatically at the next Ignition 'On' if the fault is clear i.e the battery can support starting without its voltage falling too low. If you are getting an ABS condition when trying to start the bike it is likely that the battery requires to be renewed. Link to comment
Boffin Posted February 15, 2012 Share Posted February 15, 2012 Be sure to use an analogue meter, digital meters smooth the input and can miss the dips. Andy Link to comment
KDeline Posted February 15, 2012 Author Share Posted February 15, 2012 If the faults come when you use the brakes, then reset when the ignition switch is cycled, it sounds like you're about due to bleed your brake systems. Nope, as I am driving the lights started pulsing. Not a major concern yet, but would like to know if I have a catastrophic failure looming. Link to comment
KDeline Posted February 15, 2012 Author Share Posted February 15, 2012 Be sure to use an analogue meter, digital meters smooth the input and can miss the dips. Andy Link to comment
breyfogle Posted February 16, 2012 Share Posted February 16, 2012 Be sure to use an analogue meter, digital meters smooth the input and can miss the dips. Andy Not absolutely necessary, if you have a pro-quality digital multimeter. My Fluke has a fast enough response to track the blips very nicely. I'm sure there are others. Link to comment
Joe Frickin' Friday Posted February 16, 2012 Share Posted February 16, 2012 It has been discussed, can not find the link. Anybody have it? For a 98 R1100RT. ABS faults while driving, about 3 times in the last month. Resets with startup. click here, go to bottom half of page 72. Link to comment
