Sidebag luggage is busted.
blkvelvt
When you push the button down, The latch pops up 90 degrees to the OML surface of the bag. Internal mechnism is no longer attached to the latch. Bag is sealed up closed tighter than a bulls butt.
You can probably remove the hinge screws, lift the cover a bit to retrieve the contents (if possible) and perhaps rock the cover left right to see if it unlatches for the top.
