DrMikey Posted February 6, 2012 Share Posted February 6, 2012 During the pre-spring downtime I'm thinking about maintenance beyond the usual services and inspections for my 2003 R1150RT. I has 45K miles at this point. First, is it worth rebuilding or at least thoroughly cleaning the fuel injectors? I hear differing opinions. I've noticed a bit of a surge around town, even when they're freshly sync'd. It pretty consistenly gets 41-44mpg. Second, I know of several people with the old 5-speed transmissions whose gearboxes failed at around 65K. I don't have the same data for the six speed trannys. Does anyone have a take on doing a pre-emptive replacement of bearings and shims? There are a couple shops that do, and I'm wondering if it's worth doing a teardown now, shipping the box out and hopefully getting it back in a reasonable time frame. Similar concerns about the final drive come to mind. As you know, it's a major job- I figure 10 hours for the teardown and probably twice that much for the reassembly. I hope to do a couple long trips this year. The RA National is in Colorado, and there's a group who will take the long way there via Montana. There's also a few LD Rallies later in the year that are appealing. Opinions? Facts? Admonishments? Poison pen letters? Mike in Viroqua Link to comment
Selden Posted February 6, 2012 Share Posted February 6, 2012 At 45,000 miles, the clutch should still have many miles left, but spline wear was a problem with some 1150s, and if you have never lubricated the input shaft splines, this is a good time to do so. Pull the left fairing panel, left footplate, and starter. Removing the starter reveals a small space where you can see a portion of the input shaft splines. Having just replaced a clutch, I can assure you this approach is a lot less work than splitting the bike. While you have the starter off, disassemble and clean it; dirty work, but not terribly difficult. If the transmission shifts easily, and transmission/FD oil changes have not shown anything alarming to date, I wouldn't worry about them at 45,000 miles. If in doubt, change the oil, even if it's not yet time; oil is cheap, and neither task requires a lot of time. The FD pivot bearings are likely to have developed some free play; grab the rear wheel at 9 and 3 and see if it has any play lateral movement. If it does, your options (from cheap to expensive) are 1) tighten the inside preload adjuster; 2) replace with new OEM needle bearings; 3) replace with Rubber Chicken bronze bushings. Pivot bearing replacement should take less than 4 hours. Have you ever replaced the throttle cables? BMW recommends doing so at intervals, but it's somewhat of a PITA, due to the location of the cable splitter (Bowden) box (I assume this hasn't changed significantly with the 1150 models). Since I had my R1100RT apart for the clutch work, I replaced the cables (which looked fine since the previous change 50,000 miles previously) and cleaned the Bowden box. Here's a well-illustrated post that covers many of the things you might want to consider doing: How I spent my Holiday weekend....lotsa pics I don't want to start a shocks thread, but if you are still on the original OEM shocks, you might want to do something about them. Link to comment
PAS Posted February 6, 2012 Share Posted February 6, 2012 Selden, Can you tell me which allen head and Torx head bits are needed to get to the clutch on an RT? Planning on a spring project myself. Link to comment
Selden Posted February 6, 2012 Share Posted February 6, 2012 Selden, Can you tell me which allen head and Torx head bits are needed to get to the clutch on an RT? Planning on a spring project myself. If my memory serves, I used all the sizes in the OEM toolkit: 3mm, 4mm, 5mm, 6mm, 8mm. But L-shaped hex wrenches are useless with a torque wrench, so in order to torque fasteners properly, you will need hex bits that fit a 3/8" socket drive: 5mm, 6mm, 8mm. The fastener for the rear ABS sensor requires a T25, and is the only one I remember that required a Torx bit, but I could be forgetting something. BMW recommends raising the tail; Haynes suggests removing the subframe entirely. I did the latter, which requires more work, but while it was off, provided the opportunity to clean and repaint the subframe and rewrap much of the wiring harness. Link to comment
