GordonB Posted December 7, 2005 Share Posted December 7, 2005 Okay, I sprang for the $18.00 to get a new clutch switch. I confrimed the old one was bad. Removed the dash and left side tupperware to get to the wiring harness. Located the plug connection behind the left speaker mount. Undid a gazzilion plastic ties to get the old wire off the harness (this was a dumb move....gotta put the ties back on, and I could've left the old wire there and just tie wrapped the new one to the harness). The big question!!!! How do you remove the switch from the left grip? I know it's screwed in, but how do you get at that NUT! and unscrew it? Link to comment
tgregg Posted December 7, 2005 Share Posted December 7, 2005 Mine died early on and it was replaced on warranty. It died again right after the warranty expired. I just pull the clutch in now. The switch seems to be a weak link. Link to comment
russell_bynum Posted December 7, 2005 Share Posted December 7, 2005 Cut the wire close to the switch and slip a deep, thin-wall socket over it to unscrew it. Link to comment
KDeline Posted December 7, 2005 Share Posted December 7, 2005 Cut the wire close to the switch and slip a deep, thin-wall socket over it to unscrew it. Then how to tighten the new one? Link to comment
russell_bynum Posted December 7, 2005 Share Posted December 7, 2005 Then how to tighten the new one? I used needle-nosed pliers and just did the best I could. It's been there for almost 40K miles and hasn't fallen out yet. Link to comment
GordonB Posted December 7, 2005 Author Share Posted December 7, 2005 Thant's what I figured....I'll give it a shot. Link to comment
