IMAC G5 computer. Help!
Paul Mihalka
My wonderful IMAC is becoming a PC. First occasionally, now regularly it comes up with a black square in the middle telling me in 4 languages "You need to restart your computer". A few times after one restart it worked fine. Now the last time after restart it came with the message before getting to the desktop. It took 5 times to shut down/restart before it started working again.
Any suggestions? Thanks for help!
I have the same antique; it's generally stable, but I notice that it no longer remembers brightness settings when it is restarted. I have read of video card /power supply failures. Does this sound familiar:
Does this happen while it's running, or only on startup? If the latter, don't turn it off.
You could back up all your data to an external device and re-install OS X from the disc that came with the machine, then go through all of the updates since then, but I suspect that it's an age-related hardware problem, and you should plan for a replacement. I'm guessing that your G5 is at least 6 years old (I bought mine in the fall of 2005) — it's not going to last forever.
Basically a Kernel Panic, at the UNIX level... only thing to do is restart. If it happens repeatedly, I would recommend both running Disk First Aid in the Utilities folder... Run Disk Permissions and Repair... you can't repair the drive unless you boot off of the Install Disk that came with your Mac. Also, you can zap the PRAM... With the computer off, hit the Power Button the the back and hold the Option + Command + P + R keys at the same time and hold them down (do this quickly before you hear the start up chime). Keep holding it down for about 5-6 startup chimes in a row, release the keys, and then come to the desktop. See if that helps. If you still have problems, get a copy of TechTool Pro at Micromat.com and run it from the disk. If still problems, then it is definitely hardware (you could wipe the drive and do a low level format and reinstall up to 10.5 (Leopard, the latest OS that can run on a G5 iMac from that era, and try that). If that does not help, then I would then take it in.
Thanks for the reminder -- it's been years since I reset the PRAM, which cured my monitor brightness setting.
Since you got me thinking, I also decided to boot from the OS X Install DVD, and ran Disk Utility; HD passed with flying colors. Not bad for a 6-year old, "obsolete" desktop. Other than applying regular software updates as they are released, this is the only maintenance I have performed since the fall of 2005.
The repeated kernel panic means one thing and one thing only... Somewhere in Cupertino a light on a wall is blinking to indicate that you have not spent enough money on Apple products lately. Go by a new iMac. :grin:
I think there are similar indicators in Munich monitoring our bikes (I mean wallets).
Our son likes to play with computers. He has two damaged 20" G5. One with a somewhat (fire) damaged screen, the other with bad internals. He'll make one good one out of the two, and load my back-up Hard disk. We'll see... I'm typing this on the computer of the nearby public library.
I have a computer! Son did make one working unit out of two bad ones! I'm using it. Has a nice 20" screen instead of my old 17".
Note: Looking at alternatives, I found macmall.com has new 21.5" units at $1.120.
http://www.macmall.com/p/Apple-iMac/product~dpno~8535496~pdp.gfgcadd
My emac is so old I can't upgrade to some software, specifically photoshop cs5/6, but it still works, but one of those new imacs is in my future.
