DWA Fault Code
richnewt
Got the DWA Fault Code. I think it just means to replace the AA batteries in that little box under the pillion seat approximately under the luggage rack. Am I correct? Couldn't seem to find anything by using the search function here.
  • 4 weeks later...
Thanks for the help. Got the little batteries changed and problem solved. Frustrating that the search engine on this forum doesn't recognize "DWA fault code" but does recognize "DWA warning". Hard to search effectively if you have to know the exact words to use each time a problem comes up. Anyway thanks for your help.
