Alfred02 Posted January 29, 2012 Share Posted January 29, 2012 On DR's recommendation, I start a new thread. 2004 1150RT It's been well documented that the LHS old Cam chain tensioner with the long black spring can cause a fairly noisy rattle on Startup. This tensioner has gone under multiple upgrades, with one being a "three" separate piece unit plus copper washer. From what I have found so far, the latest unit is a 2 piece unit, with the cylinder and a piston assembly (plus copper washer). These are the part numbers I have as the latest unit: 1) Piston p/n 11 31 7 656 922 2) Cylinder p/n 11 31 7 688 629 3) Washer/gasket p/n 07 11 9 963 308 Are these the latest parts ?? Link to comment
PAS Posted January 29, 2012 Share Posted January 29, 2012 Yes, I just ordered these three parts on Friday. Link to comment
Alfred02 Posted January 29, 2012 Author Share Posted January 29, 2012 Thanks PAS I can then order them this morning as well. Link to comment
4wheeldog Posted January 29, 2012 Share Posted January 29, 2012 Rubber chicken racing has a kit for just what you want to do: http://rubberchickenracinggarage.com/chain.html The upgrade is well worth the money and is easy to do. Good Luck. Link to comment
moshe_levy Posted January 30, 2012 Share Posted January 30, 2012 +1 on Rubber Chicken kit. Here's my article detailing install on a 2004 RT: http://www.mklsportster.com/Articles/mcncct.pdf -MKL Link to comment
Galactic Greyhound Posted January 30, 2012 Share Posted January 30, 2012 Thanks for that link - nicely written article. Link to comment
cris nitro Posted February 5, 2012 Share Posted February 5, 2012 Question, Does the death rattle rear it's head the instant you push the starter button? Or does it wait until the engine fires? I have been chasing a start up rattle for a year now, changing the starter, new battery, still rattles on starter operation only and goes away the instant the bike fires. Shop told me it needed a new flywheel, the bike only has 14,000 miles. I've got her apart, did the valves and pulled the stater off and the flywheel looks fine! I'm starting to suspect the tensioner??? Link to comment
Boffin Posted February 5, 2012 Share Posted February 5, 2012 Yup, it rattles until the oil pressure gets high enough to tension the chain then it quietens down. The rattle can come back at idle if the engine is very hot. The tensioner is a cheap and easy fix. Andy Link to comment
Chuck U Farley Posted February 6, 2012 Share Posted February 6, 2012 Yes, I just ordered these three parts on Friday. Whats the cost going this route? Link to comment
