BeemerBerg Posted January 7, 2012 Share Posted January 7, 2012 Been thinking about replacing my '05 RT with a camhead. Can anyone tell me if the same rear drive is being used in these newer modeld? I've had to rebuild the drive on my hexhead, and my '99 Oilhead. Would like to avoid that "cost of ownership" experience again. I understand that they've gone back to a float in the gas tank instead of that pesky fuel strip. True/False? Link to comment
Paul Mihalka Posted January 7, 2012 Share Posted January 7, 2012 2011 and on R1200 bikes have a float in the gas tank instead of the stupid fuel strip. 2005 also had a float. Link to comment
bobbybob Posted January 8, 2012 Share Posted January 8, 2012 Final drive is the same overall design but they added a vent and moved the drain plug to the bottom. If internal tweaks were made, no one seems to really know for sure. Somebody chime in and correct me if they know something different. Link to comment
BerndM Posted January 8, 2012 Share Posted January 8, 2012 2011 and on R1200 bikes have a float in the gas tank instead of the stupid fuel strip. 2005 also had a float. According to the BMW parts fiche, the 05 has the following part. Part Number Description Qty Each 16147675547 FUEL LEVEL SENSOR 1 $131.65 Definitely a fuel strip, not a float. I have the 05 and WISH it had a float. Link to comment
Paul Mihalka Posted January 8, 2012 Share Posted January 8, 2012 Checking, the '05-'07 shows fuel pump flange WITH lever sensor 16147691483, and the '08 on shows fuel pump flange WITHOUT lever sensor 16147713043. Both fiche show the fuel strip. I think the changeover from float ("lever sensor") to strip was somewhere in '06. Link to comment
ShaneK Posted January 9, 2012 Share Posted January 9, 2012 The fuel strip was changed out for a float and a vent was indeed added to the '11. Vent in theory reducing pressures buildup that could cause bearing seal blowouts. Don't know how effective it is yet, but that was good enough for me to dig into an '11. Hope that helps. Link to comment
BeemerBerg Posted January 9, 2012 Author Share Posted January 9, 2012 Nope, my early-built 2005 hexhead DEFINITELY has the notorious fuel strip....mine is kaput and I refuse to pay the $300 to replace it. Link to comment
TeSmSp Posted January 9, 2012 Share Posted January 9, 2012 Can a bike originally equipped with the strip be retrofitted with the float? Link to comment
ScottT Posted January 20, 2012 Share Posted January 20, 2012 So what is it Paul? Does my early 2005 RT have the float sensor? I wouid guess it does because I've have had any trouble with it. Here is a bit of manufacturing information on my bike. R1200RT 05-09 (K26) VIN#ZM15680 02/2005 USA I reckon someone can take this and find out if it has the strip or the float. Doesn't matter to me because it always works The ole girl turns seven years old this coming April 15th. I hope it doesn't take BMW another six or seven to built a new RED RT. Link to comment
terryofperry Posted January 20, 2012 Share Posted January 20, 2012 Scott That VIN # plugged into Real OEM shows a sensor only, no float. http://realoem.com/bmw/showparts.do?model=0388&mospid=51560&btnr=16_0698&hg=16&fg=14 Terry Link to comment
Dave_in_TX Posted January 21, 2012 Share Posted January 21, 2012 So what is it Paul? Does my early 2005 RT have the float sensor? I wouid guess it does because I've have had any trouble with it. Here is a bit of manufacturing information on my bike. R1200RT 05-09 (K26) VIN#ZM15680 02/2005 USA I reckon someone can take this and find out if it has the strip or the float. Doesn't matter to me because it always works The ole girl turns seven years old this coming April 15th. I hope it doesn't take BMW another six or seven to built a new RED RT. I have an 07 which I'm sure has the fuel strip. With with 133K miles on it, I still have the original sensor so I wouldn't assume you have the float just because you haven't had problems. Link to comment
Oil-Burner Posted January 29, 2012 Share Posted January 29, 2012 The fuel strip was changed out for a float and a vent was indeed added to the '11. Vent in theory reducing pressures buildup that could cause bearing seal blowouts. Don't know how effective it is yet, but that was good enough for me to dig into an '11. Hope that helps. Just had my '11RT 6k service done and they found the final drive leaking... there are no seals available in the US so they replaced the entire final drive?!? it's still the best motorcycle I've ever owned, even compared to my '09RT. Link to comment
Selden Posted January 29, 2012 Share Posted January 29, 2012 Just had my '11RT 6k service done and they found the final drive leaking... there are no seals available in the US so they replaced the entire final drive?!? it's still the best motorcycle I've ever owned, even compared to my '09RT. Congratulations on getting a new FD. There are no seals available in the US because the new design never leaks. Link to comment
Guest Kakugo Posted January 30, 2012 Share Posted January 30, 2012 The shaft drive itself is exactly the same as used on the Hexhead and (curiously enough) the HP2 Sport. The rear drive is different, though I cannot tell you the exact differences. Link to comment
texasaggie97 Posted January 31, 2012 Share Posted January 31, 2012 The 2011 and 2012 R 1200 RT you can drain and fill the fluid in the final drive? I know some of the earlier models you could not access the fluid without dropping the whole drive. I would not buy a bike where I could not change out the final drive fluid. So the question is do the newer models allow you to replace the fluid like the 2003 final drive. Link to comment
1analguy Posted February 2, 2012 Share Posted February 2, 2012 Can a bike originally equipped with the strip be retrofitted with the float? This is a key question. If BMW doesn't supply a retrofit replacement of some sort, then shame on them. Between my 2nd bad fuel strip, my pulsing/grabbing brakes that they refused to fix ("it measures within spec"), and worries about the future of my FD...well, let's just say that I currently own the only BMW that I'll ever own. Say what you want about Harley...when they're faced with situations like these, they'll generally provide a repair/replacement of some sort rather than just telling you to buy a newer bike if you don't like the one you have. Link to comment
BMWRich58 Posted February 6, 2012 Share Posted February 6, 2012 My 2007 GS Adv "without computer" has the *Float*. If ordered with computer then "Strip" would have been the norm. Link to comment
gordiet Posted April 6, 2012 Share Posted April 6, 2012 Well, I can tell you for sure that my 05 and 08 have fuel strips because they both have failed! GT Link to comment
