Labdaddy Posted August 24, 2011 Share Posted August 24, 2011 Hi folks, My buddy just purchased this beautiful R100t with an RS fairing,and brought it to my shop to go thru it; it's his first BMW and he wanted to learn how to torque the heads, adjust valves etc.. Well, the gauges were loose and the fairing rattled considerably. I noticed the voltmeter had no bracket. Not having a spare, we fabricated one from some heavy aluminum I had laying around. The next day I started the bike and turned the left signal on. Dashlight not flashing??? I looked to the rear and the tailight was. No turn signals and a flashing tail light. Could this new bracket be causing a problem? All wires underneath are connected. Nothing was disconnected during procedure. If the bracket was touching something on ignition wouldn't a fuse blow? Any ideas? Thanks, John Link to comment
Skywagon Posted August 24, 2011 Share Posted August 24, 2011 There are two relays mounted on the top bar of the frame. You have to remove the tank to get to them. 90% chance it is the relay. Don't get confused on the relay in the headlight bucket. If you want a picture of the relay, send me a pm with your email and I'll send you a picture. I just replaced mine on mine. Same symptoms. Link to comment
