Changing a clutch on an 1100RT
dan cata
Hi all,
I am changing a clutch on a friend's 98 1100rt. I am now at the part where the subframe has to come up in the air but something seems to keep it from doing that.
I have taken off everything that is visible that would hold the rear subframe, including the 3 screws for the airbox. It raises for ~ 10 cm and that's it.
I have done this on my 1100GS and on a k1200rs but there seems to be something extra on the RT.
Any suggestions?
Dan.
Phew... The hose that drives the gas from the engine case to the airbox masked the screws on the lateral. I Thought that the frame shoul pivot against the allen screws... Anyway, took the allen screws off and now the rear end is way up in the sealing :D
Dan.
