fuel filter fuel pump lessons
rich t
Left myself stranded Friday night and have to admit it was competely my fault.
Lesson 1:
When doing the external fuel filter mod, make sure you use high pressure SUBMERSIBLE fuel line. I originally used 50 psi, but realized that it was not submersible when I got my fuel pump out to find a frayed mess of what used to be a fuel line connecting my pump to fuel inlet. I was able to find higher pressure submersible fuel line at napa.
Lesson 2:
When doing the fuel filter mod, drop the extra $66 on the aftermarket Purolator Facet FEP 2042 fuel pump. Even though my mistake was Lesson 1. The first thing I thought when the bike died was "Why didn't I replace that stupid fuel pump while my garage floor was soaked with gasoline last time?".
Note: The fuel pump does require some type of spacer shims to fit. I used some of the SUBMERSIBLE fuel line and nylon zip ties to do this.
another Note: The above fuel pump also has flat electrical connectors vs the original BMW screw type. I elected to solder these connections.
Why aftermarket? The above fuel pump goes for $66 usd locally at NAPA. BMW lists the original for $350, others for $200. Got the parts locally and back on the road by Saturday afternoon.
