macx Posted May 13, 2011 Share Posted May 13, 2011 Going to use either oem or Mann filters - found out the wrench that fit my 1150 filter doesn't (of course!) fit the 1200 filter. Best I've seen so far is BeemerBoneyard wrench for $20 - any other options? Or, are there any wrenches at i.e. AutoZone that work? Thx! Link to comment
dirtrider Posted May 13, 2011 Share Posted May 13, 2011 Afternoon Macx I just use a cheap & simple band wrench. It works on about everything from hard to access filters on cars & trucks, to tractors, to boats with deep set engines, to the good old 1200RT. Link to comment
BerndM Posted May 14, 2011 Share Posted May 14, 2011 AutoZone sells a strap wrench for about 7 bucks. You can use either a 1/2" ratchet or a Crescent / box wrench with it. Main advantage is it stores way smaller than the pictured above. Link to comment
AZRTRDR Posted May 14, 2011 Share Posted May 14, 2011 I meant Ilium. http://www.iliumworks.com/Store_Detail.cfm?ID=229097&InfoID=5919&ShowLarge=True Link to comment
