don_k Posted May 9, 2011 Share Posted May 9, 2011 On my R1100 RT there is a small sub-frame part attached to the back of the frame and includes the two vertical supports for the aft end of the luggage rack. Both vertical supports have broken off. I plan to weld it back together but am unsure if it's stainless steel or just steel. A magnet is attracted to it so I know it's not aluminum but there are places where the paint has worn off and there is no rust on it. It would seem a bit unlikely to me (but what do I know) that the frame of the bike would have been made of stainless steel (because of the cost, but then again it is a BMW) but not impossible. Does anyone know for sure what kind of steel the frames are made of? Thanks, Don Link to comment
Boffin Posted May 9, 2011 Share Posted May 9, 2011 It is made of welded mild-steel tubing - you can see the internal seam on the tube if you look. When I got mine welded, I inserted a length of 10mm mild-steel bar into both parts and had to notch the bar to fit the seam. Andy Link to comment
don_k Posted May 9, 2011 Author Share Posted May 9, 2011 Yep, I saw the seam. I made some 2 1/2 or 3 inch inserts from solid steel bar and had to notch them for the seam. I suppose the exposed bare metal didn't rust because what ever rubbed the paint off was pressing hard enough to keep moisture out then. Thanks for the input, nice to know I don't have to go buy a tank of tri-mix and stainless wire to weld it up. DOn Link to comment
