Final Drive Oil Change
Tourbike
What is the current BMW recommended oil change frequency for the final drive on the 1200RT? And, isn't the volume now 180ml?
dirtrider
Morning Andy
I know this doesn’t directly answer your question.
A good safe and easy way is to change the final drive gear oil at every rear tire change. The rear wheel needs to come off anyway so you are over half way through the final drive service.
That’s a bit early but is a good way to keep an eye on what’s happening inside your final drive.
Doing the change when you need a new rear tire makes sense to me. I use Shinko tires and get close to 11k - 12k miles on the rear.
Herkypilot
Get some of the Honda Moly60 that's about the best stuff according to many. I bought a small cartridge which will last for years.
HP
Jerry Duke
For a few weeks they claimed the oil was good for the life of the unit. Then the units seemed to be failing so they changed their minds....
Experienced people told you their opinion, what does your manual say? Maybe you need to contact BMW.
dirtrider
Morning Andy
Last service sheet I have shows the final drive oil change at every 2 years or 20,000 KM. There might be a later service sheet (Maintenance Schedule) available though so call your dealer and have them pull up the latest Maintenance Schedule for you.
I just had my final drive rebuilt with new bearings. The service manger told me to change the fluid every 12K OR once a year, 180cc .
marcopolo
The latest maintenance schedule I have is for the so-called "BMW Inspection" (carried out every 20,000 kms) and it's the 12/2009 version. One of the items is "Changing oil in rear-wheel drive". It says nothing on the schedule for that item about a time interval, though that's not to say there's not a more recent schedule since every two years is noted above. I have my bike serviced by an independent tech. The Castrol SAF-XO gear oil for the FD costs $14, and the labour is included in the two hours he charges for the "Inspection".
marcopolo
In 2005 wasn't it supposed to be lifetime oil? I do mine every 6000.
Brian
Yes. Then BMW changed it to once, at the 600-mile service. Then they changed to the routine (every 20,000 km) interval, and reduced the fill quantity for an oil change to 180 ml.
We recently changed a FD on a GSA, the new one came with oil and ready, we found that afther draining, but the point is that the factory oil was dark and there was metallic dust on the magnetic collector, so afther a 1500km trip we changed the oil again, this time the oil looks better and there was not so significant acumulation on the magnetic collector. We decided to keep checking afther the next long trip and every engine oil change. Our conclussion is that breaking process on the FD deteriorates the oil much earlier than indicated, causing premature failure, to prevent this the oil has to be changed much more frecuently than recomended by manual.
Best regards
Japanese
dirtrider
Afternoon Japanese
They’re all dark like that on first oil change BMW puts some sort of Moly in the original gear oil, probably for gear tooth break-in. Nothing abnormal in what you found.
Afternoon Japanese
Hi, that makes sense, but the amount of metallic dust on a brand new FD, and the poor record for those FDs, the bike in question had barely 25000km when the FD failed. The new FD was almost 1800$ exworks plus shipping. Makes me feel more confortable changing the oil more frecuently.
Thanks for your kind tip, we were not even sure if the factory oil was the working one or only for storage.
Best regards
Japanese
Joe Frickin' Friday
2009 R1200RT here. I understand you fill through the ABS sensor. Does the drain plug need a crush washer? If so, anyone know what size? I have a bunch of crush washers left over from my 1100RT, and I wonder if one of them might fit.
terryofperry
Mitch
Correct me if I am wrong but a 2009 should have a seperate fill plug, not the sensor.
Terry
dirtrider
Morning Mitch
There is a fill plug but you still have to remove the rear wheel to get to it. You can almost get it with the wheel on but risk wheel damage trying.
Hi, there is a filler plug so you do not have to mess with the sensor. Drain plug has an o ring, dont remember a washer, anyway it was not neccesary to replace any hardware. Only thing was filler plug and drain were not the same, one was allen an other torx.
Best regards
Japanese
Whew! When I read that some bikes don't have a FD drain plug, I ran right out and took a good look at mine.
TGFSM! Mine has one. (2011)
Joe Frickin' Friday
Changed my FD oil this weekend.
The official BMW service manual specifies "Castrol SAF-XO" gear oil for the final drive. After checking auto parts stores near my home, I gave up and went to the BMW dealer - who handed me standard 75W-90/GL5 gear oil. Crap, I could have gotten that a mile from my house, for a lot less than $25.
On the plus side: a drain plug with an O-ring. Finally, don't need a crush washer every time I change the fluid. Yay!
On the minus side:
- a fill plug that can't be accessed without pulling the rear wheel - and even then, access is difficult through the brake rotor. You really need a syringe, and I couldn't find one in this town. Well, pharmacies did stock syringes, but they were only 10ml-capacity, intended for feeding gear oil to infants. I wasn't sure I could count to 18 without screwing up, so I opted to sacrifice one of our turkey basters - the crappy one, since we wanted to save the good one for cooking. The crappy one made the job a real PITA. As it turns out, it seems to be only able to reliably suck up about 10ml of fluid at a time - same as the infant feeder from the pharmacy (except that would have been easier to use).
-a fill plug that still requires a crush washer. Why on earth would you design the drain plug with an O-ring, but not the fill plug???
-a fill plug that uses hex keys, when every other damn bolt on the bike is Torx. WTF, over?
-the dealer, 20 miles away, who sold me the wrong damn crush washer for the job. I come all the way there and pay top dollar for their expertise in BMW motorcycles, and this is what I get? Sheesh. I ended up reusing the existing washer.
Dundee387
I use a hair coloring applicator from a beauty supply shop. It cost a buck or two, and it has ml. measuring labeled on it, so you know how much your putting in (180). Also has a long, thin, plastic tip. perfect for the job. I think it is mentioned in the JVB video.
dirtrider
Evening Mitch
A 69 cent funnel and a piece of hose makes the job ever so easy. You can use a precision measuring cup then just pour it in through the funnel/hose.
malcolmblalock
This is a stupid question, but I'll ask anyway. Why can't you use the "drain" plug (the one at about 10 o'clock) to add fluid? Seems that if it can be used to drain the fluid (on models before the bottom plug), it could be used to put oil back in.
Why not?
dirtrider
Evening siman00
Probably could now that the oil level has been reduced. I think at level final drive the bottom of that drain hole should be close to 180cc or so.
The big problem would be getting all the oil in without spilling any (so you know how much went in). The ring gear is mighty close to that rear drain plug hole so it wouldn’t be that difficult to get it to belch some of the oil out as you fill it as there is no external vent.
Paul Mihalka
I think that to use the "10 o'clock" drain plug for draining you would like to remove the ABS sensor anyways to get some air in. That hole is small and it would take forever to drain. I understand that with the new 180cc fill volume that drain plug acts as a oil level when the rear drive is installed. What I do is that after draining I re-install the rear drive and start filling through the ABS sensor hole simply with hand operated oil gun until oil comes out the drain hole. Plug up everything and you are done.
Why not?
You can, I just did it yesterday. I change my FD oil and lube the splines at every tire change, too often for some but I like the feeling of Honda Moly 60 on my fingers.
Why not?
Me too. Every 12k
Some of the knowledgeable folks here said it many times; the FD uses sealed bearings, FD oil does not lube the bearing. FD rarely fail because of FD lube. Bearings (crown and pinions) puke out first. Changing out the FD lube can not hurt, but premature lube swap based on fear of FD failure is simple waste of $$.
It's good to see someone say what I've been thinking.. :thumbsup: There's a greater chance I'll screw something up trying to fix something that ain't broken than there is I'll prevent something bad from happening that likely ain't gonna happen.. :grin:
Afternoon Sustengo?
I think you misunderstood what was said about the hexhead final drive bearings. Only ONE bearing in the hexhead final drive is sealed and that is the large crown bearing. The R/H spool bearing is a large needle setup that does run in the gear oil as well as both pinion bearing run directly in the gear oil.
What has been posted is there are very few internal bearing failures on the heaxhead final drive (well after BMW increased the size of the rear pinion bearing anyway). The one bearing that does seem to still fail occasionally is the crown bearing and that is the sealed bearing that runs outside the gear oil chamber.
On the early hexhead final drives with the smaller rear pinion bearing it probably isn’t a bad idea to change the gear oil a little more often to see if any debris from that rear bearing comes out in the drained gear oil.
When did they make the change?
Evening Jim
Sometime around August of 06 (BUT) that assumes that BMW didn’t have some early leftovers that they worked into later production.
