BchrisL Posted May 5, 2011 Share Posted May 5, 2011 I am trying to buy bearings for an engine was damaged by no oil failure and it got a little hot. The color on the crank and connecting rods looks BROWN, so I cannot decide which bearings to purchase. I can measure the crank journals, but I don't know what the specs are for the colors. Can anyone out there decipher the color codes for the crankshaft/crankshaft bearings and the connecting rod/connecting rod bearings? I would greatly appreciate and knowledge you could share on this issue. Thanks, Chris Shamelessly copied from a parts fisch for a 04 R1150RT 11211340625 BEARING SHELL YELLOW 11211340626 BEARING SHELL GREEN 11211341573 BEARING SHELL YELLOW - +0,25 11211341574 BEARING SHELL GREEN - +0,25 11217678812 GUIDE-BEARING SHELL YELLOW - +0,25 11217678813 GUIDE-BEARING SHELL GREEN - +0,25 11217678814 GUIDE-BEARING SHELL WHITE - +0,25 11217680444 GUIDE-BEARING SHELL WHITE - 60,0MM(0) 11217680444 was superseded by 11217689930. 11217689930 GUIDE-BEARING SHELL WHITE - 60,0MM(0) 11217689930 was superseded by 11217675275. 11217689927 GUIDE-BEARING SHELL YELLOW - 60,0MM(0) 11217689927 was superseded by 11217675273. 11217689928 GUIDE-BEARING SHELL GREEN - 60,0MM(0) 11217689928 was superseded by 11217675274. 11217675274 GUIDE-BEARING SHELL GREEN 11241342810 CONNECTING ROD - 3XWHITE 11241342811 CONNECTING ROD - 3XYELLOW 11241342812 CONNECTING ROD - 1XBLUE Link to comment
