B tires?
ridesmith
ridesmith
Apologies if this is supposed to be in another forum!
I'm looking at Michelin Pilot Road 2 or 3s for my 07 RT; few stores offer the B size. I occasionally ride two up. Is the B size necessary? I don't recall such an option when I bought the Conti Road Attacks I'm running now. Thanks.
Sailorlite
I've noticed that the Road Attacks installed at the factory are a "C" spec tire, and the Pilot Road 2's are a "B" spec. Are your present RA's C-spec?
I've gone both ways on the PR2's and can't tell the difference mileage-wise or performance-wise. My last two rears however have been B-spec simply because both Michelin and BMW seem to recommend it.
I don't find myself wishing I had bought the "less recommended" version instead.
ryan_a1982
Ridesmith,
I just got the non-B version of the PR3's mounted last week. I have about 1,200 miles on them so far and have ridden them on lots of different surfaces. 1-up and 2-up loaded.
I Haven't had any issues yet and the tires feel amazing.
Check out this thread discussing this same topic a couple of weeks ago:
http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=689098&page=4
ryan_a1982
Also..keep in mind that the BMW RT is much lighter than the Conti and and ST1300 etc... those bikes don't require the B-spec tire.
John Bentall
BMW have specified a reinforced tyre that allows for maximum speed, 2-up, fully loaded on an German Autobahn.
I have ordinary PR3s fitted to my bike. 'nuff said.
HTH,
John
I'm running the B version on my 05 R12RT. I have about 3,000 miles so far and it is wearing longer that the non B version. I can feel that the tire is a little stiffer and it takes a little longer to warm up. I only ride 1 up, but I will change to the standard PR3's when these wear out.
Could it be that B spec tires like BMW's maintenence schedule are made for autobahns ? My M3 engine requires Castrol 10w60 when my Accord runs on 5w20.
Overkill I think for our "slow" North American roads.
Guest Kakugo
The B version has slightly reinforced construction and uses a slightly harder rubber compound in the center. It's specifically designed for long distance riding two up to ensure the rear tyre lasts a bit longer.
Do you need it? Not really, unless you ride a lot of miles with pillion and luggage.
My RT is now on the third set of regular PR2's which is over 6000 miles old. The way I ride it's nothing short of a technological miracle they last so long.
ridesmith
Thanks for the helpful replies, I think I'll skip the B as it is hard to find, I need new tires NOW, and I don't ride fully loaded most of the time.
  • 3 months later...
I'm only getting 6000 miles on non-B tires on my 2007 R1200RT. Loaded for camping once in a while, but never 2-up. Half my miles are on 200+ days on freeways at 75.
Is the 'B Series" wearing longer then expected?
How dies the 'B Series' compare when on the twisties?
aggieengineer
I assume you're talking about Michelin Pilot Roads. I've used both versions, and believe the difference is in the sidewall stiffness. I can detect no obvious handling difference.
Tire wear is subject to so many variables that it's tough to make generalizations. I doubt there is as much difference between the current name-brand tires as internet anecdotes would have you believe.
The only tire review I would trust would come from an expert rider, on a track, comparing new tires of which he did not know the brand, on the same motorcycle, under similar weather conditions. A comparison of a worn-out brand A to a new brand B is worthless.
Interesting topic. I've wondered at the ratings before and have gotten a mixed bag when getting tires from my tire guy.
I would get 6-8K on tires on my 1100RT-P but my big fat friend gets 10-11K on his 1200RT. Even riding together he always gets better tire wear.
Sweet mysteries of life!
Couple guys in our BMW club run 45lbs cold in front and rear and getting 10k+. They say hard tire last longer if you can put up with stiff ride. Theory being stiff tire doesn't flex, doesn't heat up, doesn't get sticky, doesn't wear.
softer tire = smoother ride = good grip = faster wear
harder tire = harder ride = good slab riding = longer wear.
I'm hoping Pilot Roads solve both. Theory, ie. marketing is good, lets see how they really hold up.
Since this topic is still going I thought I would give an update. I have the non-B version of the PR3's on my 07 RT. I have about 5,500 miles on them and they have been amazing. The wear is pretty great. I have ridden about 2,000 miles of the 5.5K two-up with luggage. They are just starting to get a flat spot on the bottom and have several thousand miles left I would guess.
I have also ridden them in the rain a lot and have felt very secure. I also have ASC...and I think that helps a lot.
-Ryan
Not a mystery--the heavier guy experiences less wheel spin.
Better mileage carrying a passenger versus not, too.
Wheel spin in this case happens when a bump lifts tire off ground. It doesn't as much when bike is heavier.
