Alan D Posted April 11, 2011 Share Posted April 11, 2011 Looks like the clutch switch on my 2007 RT is going south. The manual says carefully pull back the hand grip, being careful with the heated grip wiring. Any other advice here? Link to comment
GRB60 Posted April 12, 2011 Share Posted April 12, 2011 Since nobody else did, I'll bite. What's a clutch switch? Link to comment
Swag Posted April 13, 2011 Share Posted April 13, 2011 The dealer did my switch, but I don't think they took the grip off. I think it's in the clutch housing. Link to comment
I812 Posted April 13, 2011 Share Posted April 13, 2011 The dealer did my switch, but I don't think they took the grip off. I think it's in the clutch housing. Yes! That is very similar to the LT. Mine was there.... Link to comment
Boxtop Posted April 13, 2011 Share Posted April 13, 2011 Since nobody else did, I'll bite. What's a clutch switch? Just guessing: Switch to prevent you from starting the bike in gear, unless the clutch is in? Switch to shut off the cruise control if you pull the clutch in? Maybe one switch does both. Link to comment
Alan D Posted April 14, 2011 Author Share Posted April 14, 2011 Since nobody else did, I'll bite. What's a clutch switch? Just guessing: Switch to prevent you from starting the bike in gear, unless the clutch is in? Switch to shut off the cruise control if you pull the clutch in? Maybe one switch does both. Bingo. Looks like It may come as a harness from the handle bar to near the tank. I'll be calling the dealer to order it tomorrow. Link to comment
