s3steve Posted April 9, 2011 Share Posted April 9, 2011 Another spark plug question. What is the OD of the thin wall spark plug socket. I'll be turning down a regular 5/8" spark plug socket tomorrow at work. If anybody has done this what OD works without being too thin. I tried to measure the ID but can't get my caliper in there with the plug in the way. Thanks again guys! Link to comment
Skywagon Posted April 9, 2011 Share Posted April 9, 2011 Not sure but if you have a Harbor Freight near you, you can buy this for $8.00 and it works... It's the long skinny one. http://www.harborfreight.com/catalogsearch/result?q=spark+plug+socket Link to comment
99Roadster Posted April 9, 2011 Share Posted April 9, 2011 Kobalt from Home Depot has a thin-walled socket as well. Link to comment
Satguy Posted April 9, 2011 Share Posted April 9, 2011 The OEM service tool # 12 3 510 is 20.5MM OD (.808") I have never used a turned down socket, but the OEM tool has a very thin wall. Good Luck Link to comment
dirtrider Posted April 9, 2011 Share Posted April 9, 2011 Morning Steve I have a socket I turned down to .850” and that j-u-s-t fits both my 1200 hexheads. It’s tight on one side of one engine so maybe just slightly smaller to be sure it fits yours. If I remember correctly the spark plugs are .692”-.694” across the peaks so that should leave enough meat to not split. Link to comment
s3steve Posted April 9, 2011 Author Share Posted April 9, 2011 Thanks guys! The one I have is .855" from Canadian Tire so if I take .020" off that should work fine. Link to comment
