Swordofwords Posted April 3, 2011 Share Posted April 3, 2011 the two storz or equiv. just under the seat, both right and left side, just spins. Is this going to be a quater turn or special 'stick your tongue out, apologize to it, show it a degree' type of technique. I am blessed to have to take out last years battery and put in another new one, and as we know the fairing has to come off. As it is on my mind, and we all know what is bound to happen; where would I be able to acquire a complete set of screws to keep handy? Does it get quicker and less of a big deal as the continuous removal occurs of the fairing? Even though there is fresh snow outside, it is soon to be riding weather (was yesterday, dispite the sandblasting winds). Sword Casper Wyoming 2000 R1100 RTP 1987 K100LT 1983 R80RT (/7) 1977 75/7 w/Velorex Sidecar 1958 R69 Link to comment
Jeepster Posted April 3, 2011 Share Posted April 3, 2011 Hi Sword, If your 2000 is the same as my '04 which I'm almost sure it is then yes those two "screws" are 1/4 turn release connections. On mine I usually look at the inside point and turn till the flat part is horizontal. When tightening squeeze the two panels together and push screw in and turn flat to vertical. Link to comment
AndyS Posted April 4, 2011 Share Posted April 4, 2011 the two storz or equiv. just under the seat, both right and left side, just spins. Is this going to be a quater turn or special 'stick your tongue out, apologize to it, show it a degree' type of technique. Do you mean the ones I have circled? If so, these are 1/4 turn types. They are normal hex head, but due to being plastic, the normal 3mm hex wears quickly. However, if you use a 1/8" hex bit, this normally does the job reliably. Now, if you don't mean this fastener, but the ones at the back of the tank, then they are normal M5 x 16 screws. These screw into 'slide on' on M5 body nuts. Link to comment
