StriderWalker Posted March 25, 2011 Share Posted March 25, 2011 I'm pondering purchasing a radar detector, but with the exception of the TPX, all of the options are vulnerable to weather. I've seen the "moto-radar cover" online ($65), but am interested in any other options, or anyone's experience or advice. I'm all ears! Link to comment
94aero Posted March 25, 2011 Share Posted March 25, 2011 Take a look at the "legal speeding" box. keeps my passport 8500 dry! Link to comment
scottgr Posted March 25, 2011 Share Posted March 25, 2011 For the Valentine One, I've used the V1 mount from BMR Products for several years. It's not waterproof, but a plastic baggy works fine to keep it dry. The N/Line Products box looks interesting too (http://www.brydenscot.com/?p=21), and I may give it a try one of these days. -sg Link to comment
markgoodrich Posted March 25, 2011 Share Posted March 25, 2011 Someone may step up and say this is a stupid idea, but I have mine mounted under the fairing, above the right headlight. I bought a cheap ebay "mute button" extension wire which is mounted near my left thumb. It seems to alert as soon as my friends' "open" mounted units. I have an Escort refurb unit, turned off all the laser alert stuff, and the X band, and all the blinky lights. It's wired into my Autocom...required a mono-to-stereo adapter plug from Radio Shack. Mounting hardware is very complex: a couple of zip ties and a piece of foam. I'd show photos, but that would mean I'd have to take everything apart. My cop friends tell me that you have zero chance of getting a warning if they see a radar detector. They also tell me the laser alert function is informing me I just got tagged. Link to comment
RedMac Posted March 25, 2011 Share Posted March 25, 2011 Personally, I won't do business with Legal Speeding again. See my earlier complaint about them. Legal Speeding Issue Link to comment
rdwalker Posted March 25, 2011 Share Posted March 25, 2011 Hmmm.. sorry you had trouble. For me, Legal Speeding covers do work well. This one is in use since late 2007 or early 2008, protecting an Escort detector from rain. I attached the cover, using 3M Dual-Lock strips, to a home-made aluminum U-bracket, surrounding the fog light. Link to comment
RedMac Posted March 25, 2011 Share Posted March 25, 2011 I'm sure they do work well. I wouldn't actually know since they were unable to provide me with the cover they advertised. The issue I had was the *way* they did business, if you read my post. These days I have my radar detector behind the windscreen. When I rains I put one of the plastic stretchy bowl covers over it. Not great for a downpour, but works fine for a light rain.... Link to comment
StriderWalker Posted March 26, 2011 Author Share Posted March 26, 2011 Both the polycarbonate radar box and the N/Line aluminum box look good and give some measure of security. What happens though when the detector goes off and you want to hit "mute"? It appears that once in the box, it's out of reach. Am I missing something? Link to comment
Heck Posted March 26, 2011 Share Posted March 26, 2011 With a V1, you will need the additional audio box to wire into your intercom/whatever....The audio box has vol/mute control on it that supersedes the controls on the V1 when plugged in.....With Passport..........well...... Link to comment
markgoodrich Posted March 26, 2011 Share Posted March 26, 2011 With a V1, you will need the additional audio box to wire into your intercom/whatever....The audio box has vol/mute control on it that supersedes the controls on the V1 when plugged in.....With Passport..........well...... Here you go, Heck, for the Escort. Mine works fine, I mounted the button near my left thumb on the handlebar. http://tinyurl.com/48d952j Link to comment
Heck Posted March 26, 2011 Share Posted March 26, 2011 Here you go, Heck, for the Escort. Mine works fine, I mounted the button near my left thumb on the handlebar. http://tinyurl.com/48d952j That is interesting Mark....might snag one of them if I put an Escort on Jessica's Trike.... Tnx.. BTW I didn't intend a dig on the Escort, I have 3 of them...just didn't have any need for a remote mute as they are all in vehicles within reach and without any external box on em. Wish I would have seen the aluminum enclosure referenced above before I picked up the poly box from Legal Speeding...looks a lot better and less expensive too. I was using the vacuum formed plastic cover that LS sold for the V1...I guess they discontinued it. Top came off at some point, so I needed a new top..ended up changing the whole configuration... Ah well.... Tnx again. Link to comment
RTinNC Posted March 27, 2011 Share Posted March 27, 2011 Take a look at the "legal speeding" box. keeps my passport 8500 dry! +1 .... have the same one ... work well, is inexpensive and looks nice. Not much more to ask for! Link to comment
Fightingpiper Posted March 27, 2011 Share Posted March 27, 2011 On my 06RT I used the legal speeding box and a Radar Screamer The 108 dB piezo beeper easily fits out of sight where the radio speaker would be and the low/high/off toggle switch can be attached to an existing screw on the right hand switch gear. (you'll have to get a longer screw) This way you won't have to worry about not hearing or seeing your radar when it goes off. Can be a bit startling when it goes off on a quiet night. The only problem was that on my escort 8500 the volume control on the Escort itself would dial down during rides but a piece of electrical tape fixed that. Link to comment
RedMac Posted March 27, 2011 Share Posted March 27, 2011 Take a look at the "legal speeding" box. keeps my passport 8500 dry! +1 .... have the same one ... work well, is inexpensive and looks nice. Not much more to ask for! Legal speeding no longer makes one for the 8500... Link to comment
Formerly_Capecodbeemer Posted March 27, 2011 Share Posted March 27, 2011 Otay, my suggestion is unless you are going stealth with under tupperware installation you don't need a box. Use some 3m dual lock and mount it to your master cylinder cover. Riding in Va, or going into the store, or if it starts raining, pull it off and tank bag it. Are you really riding at "arrest me" speed in the rain, or do you turn it down a notch ? Link to comment
Fightingpiper Posted March 28, 2011 Share Posted March 28, 2011 Take a look at the "legal speeding" box. keeps my passport 8500 dry! +1 .... have the same one ... work well, is inexpensive and looks nice. Not much more to ask for! Legal speeding no longer makes one for the 8500... Their RADAR BOX works just fine with the escort 8500..... Link to comment
Starfighter Posted March 28, 2011 Share Posted March 28, 2011 +1 what Sandy said. I tour with ziplocks in my pocket for ???? In rain I slow down so......drizzle I put a ziplock on my detector, rain, I put the detector away...... Link to comment
Polo Posted March 28, 2011 Share Posted March 28, 2011 Darn, somebody had to come out and ruin a perfectly good thread with ridiculous common sense. Link to comment
JonathanE Posted March 29, 2011 Share Posted March 29, 2011 Otay, my suggestion is unless you are going stealth with under tupperware installation you don't need a box. Use some 3m dual lock and mount it to your master cylinder cover. Riding in Va, or going into the store, or if it starts raining, pull it off and tank bag it. Are you really riding at "arrest me" speed in the rain, or do you turn it down a notch ? What Cod said. I have a clear plastic cover for my V1, but I've never used it. When it rains, I put the V1 in a pocket or a saddle bag and ride no faster than I feel safe riding, which is usually within LEO tolerance. Never been stopped riding a bike in the rain, and don't think I need to worry about radar but that may be because I am not all that fast in the rain. Link to comment
