OlGeezer Posted March 17, 2011 Share Posted March 17, 2011 It's my turn! I've got a new bulb and socket. I've been told there are solutions abound, but the search feature has failed me. I would like to be able to change the bulb on the road, although this isn't life and death since it's the high beam. It would be nice if I didn't have to take off the nose to perform this operation, but that means I would have to find a ground spot aft of the black cover. I could install an electrical plug in the cover, run a wire from the bulb to the cover then a wire from the cover to a ground spot. Am I overthinking this? What is the best way to do this? What is the easiest way to do this? Thank you, Link to comment
Dallas Posted March 17, 2011 Share Posted March 17, 2011 I'm also interested to see what suggestions people have for this. Link to comment
jrcarpenter Posted March 18, 2011 Share Posted March 18, 2011 I drilled a hole in the plastic cover, ran the new ground wire through a rubber gromment with a little silicone sealer, and looped a little extra wire inside. If I need to get to the bulb it lets you have enough slack to get the cover out of the way. Jr. Link to comment
OlGeezer Posted March 18, 2011 Author Share Posted March 18, 2011 I drilled a hole in the plastic cover, ran the new ground wire through a rubber gromment with a little silicone sealer, and looped a little extra wire inside. If I need to get to the bulb it lets you have enough slack to get the cover out of the way. Jr. I like that solution. It's simpler than my idea and has less tendency to fail. What gage wire did you use? Where did you run your lead at the bulb/socket? Link to comment
jrcarpenter Posted March 18, 2011 Share Posted March 18, 2011 It's been a while since I did it. I just used what I could find laying around at the time. I believe the wire was 12 - 14 gauge(plenty big). As for the bulb connection, I used a double ground terminal off from a 1970 VW bug. It looks like a squared U with two male terminals. I don't remember exactly how it all went together, but I think you have to grind the original spring strap that holds the bulb tight in the holder so that the new terminal fits onto it. (like a normal male/female connection) Then the new ground wire with a female terminal slides on to the other end of the double terminal to the new ground location. It is a tight fit trying to get all of the wires through the small slot with the bulb lead. As I think about it, the reason for the double terninal is that you can't solder to the spring strap, and I might not have soldered a female terminal to the new ground wire, but soldered the wire directle to the double terminal in order to save space. Sorry that this is so vague, but I did it over a year agoe. If you have any questions just let me know and I'll try to answer them. Link to comment
