CarlosB Posted March 16, 2011 Share Posted March 16, 2011 Hi, I'm servicing my hydraulic clutch with a fluid change & bleed and am following the "Hydraulic Clutch Bleed Walk-through". Seem fairly easy so I'm not having any problems. That is until the very end with leaving the speed bleeder in place or not. Can there be a problem with it left in place? The "running with scissors" type! makes wonder. Any thought? Thanks, Carlos Link to comment
dan cata Posted March 16, 2011 Share Posted March 16, 2011 Why don't you just remove the bleeder and install the nut that screws in there for a better night sleep? Dan. Link to comment
dirtrider Posted March 16, 2011 Share Posted March 16, 2011 Morning Carlos If you removed the “factory fill” check valve assembly then installed the speed bleeder directly into the end of the remote clutch bleeder hose then no problem leaving it in (be the same as leaving a speed bleeder in a brake caliper) as it is tightened firmly into it’s seat when done. On the other hand if you used the speed bleeder directly into the end of the “factory fill” check valve assembly you should remove it and replace the factory sealing plug. Link to comment
AndyS Posted March 16, 2011 Share Posted March 16, 2011 DR....that's the way to do it. Link to comment
CarlosB Posted March 16, 2011 Author Share Posted March 16, 2011 Thanks... Now I can just get rid of that fill adapter ($50.00 at dealer) that I just about ruined while drilling out the grab screw that had been rounded out. Now I can get a better night sleep. Thanks all for your help. Carlos Link to comment
TracyMurphy Posted March 17, 2011 Share Posted March 17, 2011 Hi Carlos, I just did this project. Be sure you have a flare nut wrench to hold the fitting on the fill hose. The fill adapter on mine was REAL HARD to get off. Link to comment
CarlosB Posted March 17, 2011 Author Share Posted March 17, 2011 Hi Tracy & your right about needing a flare nut wrench my is the same way. I'll have to get a metric wrench, most of my tools are SAE. Carlos Link to comment
ESokoloff Posted March 17, 2011 Share Posted March 17, 2011 Try heating the fitting up. Heat softens the thread locker on the threads. Just don't over do it & melt the plastic hose DAMHIK Link to comment
boxerboy11 Posted March 17, 2011 Share Posted March 17, 2011 That is how I got mine off by using some heat on the metal of the hose and vise grips on the barrel of the adapter. Not a pretty solution but did work. BB Link to comment
