Mamelukesword Posted March 4, 2011 Share Posted March 4, 2011 I am looking for an owners manual for my RT. I found the PDF maint manual. I hoping that someone has the original owners manual PDF also. Thanks Link to comment
AndyS Posted March 4, 2011 Share Posted March 4, 2011 Oddly, I have never found a PDF version, but if you do find one, let me know. Andy Link to comment
tallman Posted March 4, 2011 Share Posted March 4, 2011 Available thru dealer (order) not too $$$. Link to comment
Mamelukesword Posted March 8, 2011 Author Share Posted March 8, 2011 OK if I get my hands on one I am making a PDF for the forum. Link to comment
Rex R Posted March 9, 2011 Share Posted March 9, 2011 I have one. If there's something in particular that you're looking for, I can scan and email/post a few pages. But you're really not missing much. Link to comment
Mamelukesword Posted March 9, 2011 Author Share Posted March 9, 2011 Really just looking for a manual. I was having trouble with the fast idle lever. I wanted to check that I was using correctly. Link to comment
AndyS Posted March 9, 2011 Share Posted March 9, 2011 Well, if that's is all you want, try these. PS don't stop hunting for that users handbook. a/. (Throttle body synch) http://advwisdom.hogranch.com/Wisdom/TBS4Dv1.0.pdf b/. (maintenance manual) http://www.ibmwr.org/r-tech/oilheads/R11Manual/Oilhead_Maintenance_2-25-02.pdf c/. (fork seal change) http://advwisdom.hogranch.com/Wisdom/Oilhead%20Fork%20Seal%20Replacement.html d/. (Ignition timing) http://advwisdom.hogranch.com/Wisdom/Oilhead%20Timing%20The%20Easy%20Way.html e/. (rocker end float adjust) http://advwisdom.hogranch.com/Wisdom/OREPADv1.0.pdf a few to keep you busy. Andy Link to comment
Rex R Posted March 9, 2011 Share Posted March 9, 2011 Really just looking for a manual. I was having trouble with the fast idle lever. I wanted to check that I was using correctly. I'll try to scan that page on Fri. Then I need to figure out how to post it. Link to comment
Rex R Posted March 25, 2011 Share Posted March 25, 2011 Sorry its been a while, sword. But I scanned the pages on the fast idle lever (and on the brake system). If someone could tell me how to upload the pdf files/post a link in a message, I'll share them with the board. Link to comment
rtp Posted March 25, 2011 Share Posted March 25, 2011 Hi, I've got an RT-P but they're pretty much the same bike. You can access manuals at: http://www.bmwmc.net The Tech information menu has the repair manuals. I believe there are other manuals on the site as well. They're all in PDF format too. I've printed them out to have in the garage already. Good luck! Link to comment
Mamelukesword Posted March 26, 2011 Author Share Posted March 26, 2011 PM sent Rex, I will check the site out rtp, thanks. Link to comment
ellaguru2u Posted July 9, 2011 Share Posted July 9, 2011 Hi, I've got an RT-P but they're pretty much the same bike. You can access manuals at: http://www.bmwmc.net The Tech information menu has the repair manuals. I believe there are other manuals on the site as well. They're all in PDF format too. I've printed them out to have in the garage already. Good luck! I cant seem to access the R1150Rt manual on this site, is there a technique? Link to comment
rrdawho Posted September 10, 2011 Share Posted September 10, 2011 Needs login information Link to comment
