John Ranalletta Posted March 1, 2011 Share Posted March 1, 2011 When powering up the cable box and Bravia, the Bravia defaults to the TV or coax port. This necessitates having to manually switch the input to HMDI port 1. Anyone know if the HDMI port can be set as default? TIA Link to comment
moshe_levy Posted March 1, 2011 Share Posted March 1, 2011 I have the same issue. Cable box goes to HDMI Port 1, and Blu Ray to Port 2. If the Blu-Ray's turned on for any reason, whether cable box is on or not, TV defaults to Port 2. Strange. -MKL Link to comment
John Ranalletta Posted March 1, 2011 Author Share Posted March 1, 2011 Would it default to port 2 if you switched the cable box and Blu Ray? Link to comment
E30TECH Posted March 1, 2011 Share Posted March 1, 2011 Are you using the coax/tv port at all? On some TVs, you can delete inputs. What type of remote are you using? Some remotes can be programmed to automatically switch the input when you power a device on. With my Harmony One, if I hit the "Watch Bluray" button, the TV goes to the proper input, the bluray player will come on and the receiver goes to the correct input. When I hit "Watch TV", it will shut the receiver and bluray player off, and switch the TV to the proper input. Link to comment
moshe_levy Posted March 1, 2011 Share Posted March 1, 2011 John- I'll experiment and let you know. No big deal to switch the inputs, but still, a default would be nice. -MKL Link to comment
John Ranalletta Posted March 1, 2011 Author Share Posted March 1, 2011 The coax TV port is not being used. The cable box serves HDMI to the HDMI 1 port on the monitor. I cannot delete ports. The remote is an Xfinity-provided unit. Doesn't appear to have programming functionality like the Harmony. Link to comment
