scottgr Posted February 28, 2011 Share Posted February 28, 2011 Did a search and came up with several different answers (5.8, 6.5, 6.65mm).... Does anyone know offhand what the thickness is for a new 1150rt friction plate? Thanks -sg Link to comment
OoPEZoO Posted February 28, 2011 Share Posted February 28, 2011 I had also read all sorts of numbers. I measureed my old and new clutch disks back when I replaced mine. I measured 5.00mm on the worn disk and 6.00mm on the new disk. My clutch was slipping and I was beginning to get intot he rivets on the disk, so it was definitely shot......even though technically is was still "OK" by wear standards. Here is a link to my little adventure LINK Link to comment
dan cata Posted February 28, 2011 Share Posted February 28, 2011 Did a search and came up with several different answers (5.8, 6.5, 6.65mm).... Does anyone know offhand what the thickness is for a new 1150rt friction plate? Thanks -sg As guess you are asking because you want to repair your friction plate? If so, get some ferodo material from the auto store and rivet it to the OEM plate. If the thickness is 8 mm in the end, you can add 2 mm spacers under each of the 6 replaceable screws that hold everything together Dan. Link to comment
ron c Posted March 1, 2011 Share Posted March 1, 2011 I asked this question a year ago. One reply said 6.65mm and another reply said 6.52mm. Link to comment
