dan cata Posted February 27, 2011 Share Posted February 27, 2011 Hi, A friend is parting a 98' 1100GS. I don't exactly remember, but is it worth to change the plastic intakes and swap them with the ones on my 96' RT? Dan. Link to comment
Boffin Posted February 27, 2011 Share Posted February 27, 2011 For the 1100RT, fitting 1100GS intake tubes - the ones that go into the airbox - gives a noticeable increase in mid-range power, at the expense of top-end power. For most real-world riding it is one of the best mods you can do to the 1100RT. For us 1150 owners however, there are no such easy gains to be had. Andy Link to comment
flat_twin Posted February 27, 2011 Share Posted February 27, 2011 My R1100RS has GS intake tubes and I like the increased midrange bump. I get more joy from the extra "honk" than I did from the aftermarket exhaust system I got rid of. Give it a try, it's easy to put back if you don't like it. Link to comment
aterry1067 Posted February 27, 2011 Share Posted February 27, 2011 I did this mod to My RT and was pleasantly surprised at the difference. One thing to note, there is an o-ring under each tube at the throttle body. If you are near a dealer, pick two of those up. One of mine fell apart when I took the old tube off. I couldn't find an exact match at autozone, but the guy behind the counter found something pretty close, just a little long. I managed to trim it and rtv it at the split, and this worked well enough, but I got a new one the next time I was at the dealer. Link to comment
dan cata Posted February 27, 2011 Author Share Posted February 27, 2011 I did this mod to My RT and was pleasantly surprised at the difference. One thing to note, there is an o-ring under each tube at the throttle body. If you are near a dealer, pick two of those up. One of mine fell apart when I took the old tube off. I couldn't find an exact match at autozone, but the guy behind the counter found something pretty close, just a little long. I managed to trim it and rtv it at the split, and this worked well enough, but I got a new one the next time I was at the dealer. Hi, That's funny, I supply those large o-rings together with the repair kits for the TB's. Thanks all, I'll ring my friend and get the tubes Dan. Link to comment
NonComp Posted February 27, 2011 Share Posted February 27, 2011 Just in case someone is interested, the GS handguards also fit the R1100R roadster. I've also got the GS tubes on my 11R. They make a bit of a boomy sound, but run nicely. Link to comment
SKYGZR Posted February 28, 2011 Share Posted February 28, 2011 During the R's current down time/winter service, this mod's been installed. Haven't fired it up yet to see how it runs, kinda waiting for the spring to do the check ride. Link to comment
dan cata Posted February 28, 2011 Author Share Posted February 28, 2011 They make a bit of a boomy sound, but run nicely. Can you be more specific about the above? Anyway, I have ordered the tubes, but will not mount them until I will have to get the fairing off for some reason... Dan. I have also read somewhere a while ago, that GS owners want the RT intakes and the RT owners want the GS intakes. Is that true? Do RT intakes performe better at low rewing, that would be usefull to GS offroading? Link to comment
Joe Frickin' Friday Posted February 28, 2011 Share Posted February 28, 2011 They make a bit of a boomy sound, but run nicely. Can you be more specific about the above? Part of any engine's noise is sound coming from the intake system. When you put GS tubes on the RT, it changes the way your engine's intake sounds; there's noticeably more noise coming from it. Not awful/obnoxious, but noticeable. Link to comment
scottgr Posted February 28, 2011 Share Posted February 28, 2011 +1 on the GS tubes. They made a noticeable difference on my RT and I'm glad I did it. Link to comment
Glenn Reed Posted February 28, 2011 Share Posted February 28, 2011 Where did those of you who have done this acquire your GS tubes? I just checked beemerboneyard and the best I could do is sign up for an email alert when available? Link to comment
Joe Frickin' Friday Posted February 28, 2011 Share Posted February 28, 2011 Got mine from the dealer. Not bad, something like $40 back in 2002. Link to comment
Glenn Reed Posted February 28, 2011 Share Posted February 28, 2011 Thanks Mitch, I will check on that. Link to comment
AndyS Posted February 28, 2011 Share Posted February 28, 2011 Currently: R1100GS BMW P/No. 13711341405 INTAKE MANIFOLD LEFT x 1 @ $30.48 BMW P/No. 13711341406 INTAKE MANIFOLD RIGHT x1 @ $30.48 Link to comment
roughwaterjohn Posted March 1, 2011 Share Posted March 1, 2011 Where did those of you who have done this acquire your GS tubes? I just checked beemerboneyard and the best I could do is sign up for an email alert when available? They're really good about e-mailing back. Everything I've put in an e-mail request for, I received a reply with parts available within a couple of days. Link to comment
NonComp Posted March 1, 2011 Share Posted March 1, 2011 I was on a waiting list at Beemer Boneyard for a gearbox a couple of years ago. I did get an e-mail when my name came up to the top of the list and one was available. Link to comment
dan cata Posted March 22, 2011 Author Share Posted March 22, 2011 Last Saturday I managed to mount the new tubes. Also, new TB's having the splitter cable box unlike the OEM setup for my '96 RT that used to be a single cable for both TB's. After mounting them, did a sync for both idle and 2500 RPM. Sync was done in the garage, not while riding as some of you do. Anyway, I am dissapointed in the results. It may only be me, but after a 400 km ride after the job was done, I have noticed a small hesitation around the 4k RPM range, in all gears... This was not there before the mod was made, but like I said, it could only be my ilussion. :| Dan. Link to comment
AndyS Posted March 22, 2011 Share Posted March 22, 2011 Hi Dan, I am pretty sure it is not the tubes themselves causing this problem. I would revisit the installation and double check the throttle operation and also any air leak issues. There is no way you could have nocked the throttle position sensor?? Andy Link to comment
dan cata Posted March 22, 2011 Author Share Posted March 22, 2011 Hi Dan, I am pretty sure it is not the tubes themselves causing this problem. I would revisit the installation and double check the throttle operation and also any air leak issues. There is no way you could have nocked the throttle position sensor?? Andy :| Forgot to check/adjust if needed. You may be right. I know the TPS only works for some angle of the butterfly, like untill you reach 4k rpm, and then it isn't taken into consideration by the motronic brain. I know this because I once got the plug off my TPS on the GS, and the bike ran like crap untik 4k rpm, then reved normally. Will give it a check next time the fairing is off Dan. Link to comment
