BFish Posted February 26, 2011 Share Posted February 26, 2011 ...more specifically the secondary plugs. here's my issue/question... realize this is not rocket science, but do any of you know if the Bosch OEM (YR6LDE) spark plugs will fit in the spark plug tool that came in the tool kit? the NGK's do. i do not have a thin sided spark plug wrench. have always used the tool that came in the kit for the secondary, which means i've always used the NGK OEM plugs, but i've located some Bosch's. the primary is no issue. i'm about to grind a socket down if the Bosch's don't fit and just go with autolite's. Thanks. Link to comment
Heyfrank Posted February 27, 2011 Share Posted February 27, 2011 yes it does. Easy to get to. Have fun. Link to comment
BFish Posted February 27, 2011 Author Share Posted February 27, 2011 thanks. all set. Link to comment
