ElevenFifty Posted February 17, 2011 Share Posted February 17, 2011 Doh ... I'm installing a front fork seal, have everything apart, fluids ready ... new seal in hand. Which side is the top? Side 1 - small product id info around the rim, 1/16" gap where circular spring sits, very slight taper around outer ring Side 2 - 1/8" gap, no id info, no taper. When do I tighten the grub screw/valve? 1. With forks compressed? 2. With forks extended? 3. With forks neutral? Thanks as always - DH Link to comment
AndyS Posted February 17, 2011 Share Posted February 17, 2011 Doh ... I'm installing a front fork seal, have everything apart, fluids ready ... new seal in hand. Which side is the top? Side 1 - small product id info around the rim, 1/16" gap where circular spring sits, very slight taper around outer ring Side 2 - 1/8" gap, no id info, no taper. When do I tighten the grub screw/valve? 1. With forks compressed? 2. With forks extended? 3. With forks neutral? Thanks as always - DH Hi DH, The grub screw is done when all is back together under neutral conditions (althogh it doesn't matter that much. See below pics for seal orientation. Andy Link to comment
ElevenFifty Posted February 17, 2011 Author Share Posted February 17, 2011 Thanks Andy DH Link to comment
