myblubeemer Posted February 13, 2011 Share Posted February 13, 2011 I tried taking my mirrors off on my 2010 RT in the traditional way. I stood facing the mirror, grabbed the upper and lower front lips of the mirror and pushed towards the rear of the bike. No matter how hard I pushed or hit the back of the mirror with the palm of my hand, neither side would budge. Am I missing something? Is there something else that needs to be done to remove the mirrors? Thanks for any advice. Link to comment
99Roadster Posted February 14, 2011 Share Posted February 14, 2011 Careful, there's a screw in there somewhere. Others will pinpoint for sure but look carefully. Link to comment
myblubeemer Posted February 14, 2011 Author Share Posted February 14, 2011 So there is a screw on the 2010 model that must be removed before you apply a rearward blow with you palm??? Where? Link to comment
philiph24 Posted February 14, 2011 Share Posted February 14, 2011 There is a hole under the mirror that you have to insert a torx into its a pain to do util you no where the screw is located.You do not have to remove the screw fully just a few turns.The smaller 1 of the 2 that comes with the bike is the right size.When you undo this the glass will come out giving you access to the screws to remove the mirror case.You have to probe about a bit to find the torx well i did anyway.Hope this helps. The mirrors on the 2010 are a different design they dont come off in a fall. Link to comment
myblubeemer Posted February 14, 2011 Author Share Posted February 14, 2011 Thanks!! Finally loacted the screw on the left mirror. After taking that one off the right was pretty easy. Man what a design. For you guys with 2010's, DO NOT try to knock it off like the previous models. Joel Link to comment
beemer23 Posted February 15, 2011 Share Posted February 15, 2011 Just curious why you are removing the mirrors? Link to comment
myblubeemer Posted February 15, 2011 Author Share Posted February 15, 2011 We are preparing this bike for the upcoming Iron Butt Rally and are adding some auxillary lights that required removing the mirrors for mounting supports. Link to comment
