Bob Grebin Posted February 12, 2011 Share Posted February 12, 2011 Hi Guys, I have a 03 RT when I went to go for a ride a couple of weeks ago, it cranked and cranked but refused to fire up. Pulled a plug and it was bone dry. Eventually I checked the fuses and #6 was blown, replaced it and it blows as soon as I start cranking.It was running fine the last time I had it out, any suggestions on where to start trouble shooting. Thanks, Bob Link to comment
dirtrider Posted February 12, 2011 Share Posted February 12, 2011 Evening Bob Start by removing the fuel pump relay then installing a new fuse, then crank it over. If it still blows then suspect the 02 sensor wire pinched or burnt on the exhaust, or an injector power wire pinched or grounded, or possibly a problem with the purge valve being shorted. If removing the fuel pump relay keeps the fuse from blowing then try swapping relays with another like relay from the fuse box, if it still blows the fuse you more than likely have a seized fuel pump or pinched/grounded pump power wire. Link to comment
Bob Grebin Posted February 13, 2011 Author Share Posted February 13, 2011 Dirt Rider, thanks for giving me a place to start.I will work my way through the list in the A.M. Bob Link to comment
