mrduck Posted February 11, 2011 Share Posted February 11, 2011 I just came back from the local Cycle Gear store.... I asked the young hottie behind the counter about grips for my BMW, she flips through a book, never asks what model, then says "come back here let me show you what I've got!" Sold me a set of standard 7/8ths bar size street bike grips. I have no problem cutting off the old rubber grip as it's half torn up. But before I start, thought I'd better ask here first, don't wanna tear things up to find out this ain't gonna work 04 RT Don J Link to comment
CoarsegoldKid Posted February 11, 2011 Share Posted February 11, 2011 I would say you are good to go. Start cutting. If you have bar ends you can remove then you can measure the bar diameter just to be sure. My Ducati has 1-1/8 inch bars but taper to 7/8 at the grip. Harley may be different though. Link to comment
mrduck Posted February 11, 2011 Author Share Posted February 11, 2011 'morning Joe I've been doing some measuring on the bars, looks like the throttle one will fit-1 inch- may have to go back to Cycle Gear for a second set and just use the big one.. These are for the sportbikes, they didn't have any ones with chrome skulls that would work Don J Link to comment
Steve W. Posted February 11, 2011 Share Posted February 11, 2011 If you have heated grips you need two throttle side grips. BMW # 32 72 1 458 396. Cheers Link to comment
Peter Parts Posted February 12, 2011 Share Posted February 12, 2011 Cylindrical grips are just one more example of moronic ergonomics often found on bikes. Wrap rubberized cork elliptical cross-section bicycle handlebar tape into the size and shape that agrees with your hand.* Ben *If your grip is about 1.5 inches in diameter and cylindrical, use the ordinary grips. Link to comment
dirtrider Posted February 12, 2011 Share Posted February 12, 2011 I just came back from the local Cycle Gear store.... I asked the young hottie behind the counter about grips for my BMW, she flips through a book, never asks what model, then says "come back here let me show you what I've got!" Sold me a set of standard 7/8ths bar size street bike grips. I have no problem cutting off the old rubber grip as it's half torn up. But before I start, thought I'd better ask here first, don't wanna tear things up to find out this ain't gonna work 04 RT Don J Morning Don Yes, you will need two throttle side grips (if you bike has heated grips). If your bike has heated grips--Be VERY/VERY careful when cutting the original grips off the bars as they are glued to the heating elements underneath. Even if very careful and you work slowly/carefully you will more than likely pull some of the grip heating element coating off the heaters (slowly roll the original rubber back over itself while carefully cutting with a sharp utility knife or razor blade) . Make sure the heaters are working and the wires are in place and glued down before installing the new outer rubber grips. They make a special grip glue if you want to look for that. Personally I use a heavy duty MotorCross grip glue on my off-road bikes to positively keep the grips in place but on my street bikes I just use my wife’s hair spray as that seems to work OK for street usage. Link to comment
SAAB93driver Posted February 12, 2011 Share Posted February 12, 2011 everything you need to know about changing just the grip part is here oilhead grip replaclement Link to comment
ESokoloff Posted February 12, 2011 Share Posted February 12, 2011 don't wanna tear things up to find out this ain't gonna work 04 RT Don J If they dont work, these will. Link to comment
Jerry Johnston Posted February 13, 2011 Share Posted February 13, 2011 It's a hell of a lot easier to slip some foam sleeves over your old grips and more comfortable also. Link to comment
Heyfrank Posted February 14, 2011 Share Posted February 14, 2011 I just saw this. I have been using tennis racket grip tape. works pretty good. Go ask the hottie at cycle gear if they sell the stuff. Sporting goods store or walmart should have the stuff also. Link to comment
NeilCW Posted February 14, 2011 Share Posted February 14, 2011 It's a hell of a lot easier to slip some foam sleeves over your old grips and more comfortable also. That's what I did, Grip Puppys work great and make my hands more comfortable on a long ride Link to comment
JDog Posted February 14, 2011 Share Posted February 14, 2011 Interesting on the different views on this. I put on Grip Puppies a couple of years ago, and within a few days, both my forearms were sore/cramping. I took the Grip Pups off, and that handled the pain. I now use tennis grip strips----very comfortable and can tailor them to your grip. Link to comment
2001-R1100RT Posted February 25, 2011 Share Posted February 25, 2011 I haven't heard the hairspray trick in years. The best hairspray is the cheapest stuff you can find. The cheap stuff is basically spray lacquer so once it dries the grips won't be going anywhere. Before grip glue that's what we used in dirt bikes in the 70s. Another option is 3M 08011 (Black) or 08001 (Yellow) Super Weatherstrip adhesive. Be sure to follow the directions and you grips will stay on through a nuclear explosion. Link to comment
AndyS Posted February 25, 2011 Share Posted February 25, 2011 Another option is 3M 08011 (Black) or 08001 (Yellow) Super Weatherstrip adhesive. Be sure to follow the directions and you grips will stay on through a nuclear explosion. Welcome to the forum, I had a quick look at your profile to see where you pass times were(because your avatar looked interesting), anyway, you haven't filled it out, so that didn't help! On to my point, I would be cautious of using anything to powerful because the grips will need to come off again when they wear out, so if you have heated grips and too powerful an adhesive, then the element will be destroyed. Andy Link to comment
cris nitro Posted February 25, 2011 Share Posted February 25, 2011 I bought the grip puppies and they made the grips too large for my hands. Didn't like them and took them off. Also tried tennis racket tape and that also made them too large for my liking. What I am looking for is a very thin neoprene cover. I'll probably go with replacing the grips with ones from Pro Grip and do the very careful removal around the heaters. Link to comment
AndyS Posted February 25, 2011 Share Posted February 25, 2011 In that case, why not just replace them with the stock BMW ones? Andy Link to comment
SAAB93driver Posted February 25, 2011 Share Posted February 25, 2011 In that case, why not just replace them with the stock BMW ones? Andy Agreed, it takes longer to read this thread than it does to replace the things. Hardest part is ordering them from the dealer. Link to comment
Ken Denton Posted February 26, 2011 Share Posted February 26, 2011 Try this fohttp://www.kmart.com/shc/s/p_10151_10104_9990000083808211P?vName=Fitness%20&%20Sports&cName=RacquetSports&sName=Racquetball%20Balls%20&%20Access&sid=KDx20070926x00003a&ci_src=14110944&ci_sku=9990000083808211Pr simple Link to comment
