weld86 Posted February 10, 2011 Share Posted February 10, 2011 I couldn't find a thread with my issue. So here goes. I have a L-1 Autocom on my RT. The issue is, it doesn't work unless the rider and passenger leads are hooked to speakers. In other words. I the rider cannot hear an Ipod or radar det. without the passenger lead plugged in. I can't find anything in the instructions etc. Anybody got an idea. This doesn't make any sense because that unit is sold with only one headset. Link to comment
SuperG Posted February 10, 2011 Share Posted February 10, 2011 Does your Autocome has a volume fader ( btw rider and pass. ) make sure it is turn to rider. Link to comment
bobbybob Posted February 10, 2011 Share Posted February 10, 2011 I couldn't find a thread with my issue. So here goes. I have a L-1 Autocom on my RT. The issue is, it doesn't work unless the rider and passenger leads are hooked to speakers. In other words. I the rider cannot hear an Ipod or radar det. without the passenger lead plugged in. I can't find anything in the instructions etc. Anybody got an idea. This doesn't make any sense because that unit is sold with only one headset. Is your unit being powered by a 9 volt battery instead of the bike's battery? If so, I believe the unit is turned on by plugging in the rider headset under this condition. Is it possible you are plugging into the passenger headset cable instead of the rider cable? Link to comment
SuperG Posted February 10, 2011 Share Posted February 10, 2011 Bingo!! I also plugged mine in the wrong one (passenger) For some odd reason the long one is the drivers and the short one is the passengers. I guess if you trunk mount it it is ok , but then I need a super long 3.5mm cable extension to run GPS- radar detector mp3 sound back to the trunk. It is easier for me to just mount it in front ( tank bag or glove box). Link to comment
weld86 Posted February 11, 2011 Author Share Posted February 11, 2011 It is bike powered. I have not had a chance to mess with it. Autocom UK got back to me very quickly. They said basically the same thing. They did say to disconnect everything and then reconnect. If the problem persisted. Send it back and they would check it out. I'll post results Thanks. Link to comment
weld86 Posted February 13, 2011 Author Share Posted February 13, 2011 More Info. I'm using pre 2009 headset leads with an outlet for in ear speakers. When I attach a headset with speakers to the 7 pin connection. The in ear speaker port works. If not attached it goes quiet. I'm starting to think I cannot interchange pre 2009 parts with the new style. Link to comment
AdirondackJack Posted February 13, 2011 Share Posted February 13, 2011 You are right. If you want good information on this, search out Rocketmoto on this forum and he will be able to answer all of your questions and will most likely have any autocomm parts you need in stock. Link to comment
John Bentall Posted February 14, 2011 Share Posted February 14, 2011 You're fine so long as the headset has a 7-pin connection. One cannot (should not?) use a non-LOGIC headset with a LOGIC hub as the LOGIC speakers are 8-ohm and everything else takes 32-ohm. 8-ohm speakers are easier to drive thus improving battery life when not bike powered. Link to comment
