RoanokeRider Posted January 15, 2011 Share Posted January 15, 2011 Has anyone replaced the hose from the preload adjuster to the rear shock on a 2004 R1150RT? The parts fiche does not show it as a seperate part and does not even show the gasket/crush washer for the banjo bolt. The hose appears to be leaking where the banjo fitting conects to it. Any info on how to replace this hose would be appreciated. Link to comment
Boffin Posted January 15, 2011 Share Posted January 15, 2011 It is supplied as part of the rear shock. The hose however, is a simple hydraulic line and any hose-repair service should be able to fix it or make a replacement easily enough. The fittings are standard metric hose couplings/washers. Andy Link to comment
RiceToy Posted January 16, 2011 Share Posted January 16, 2011 Assuming you tried tightening it? I had preload adjuster leak where the hose fitting connects near the top of the shock. Pulled the shock, tightened the fitting, re-filled the preload oil - rides like new (as far as I can tell). Link to comment
RoanokeRider Posted January 17, 2011 Author Share Posted January 17, 2011 The hose at the banjo bolt has the outer casing pulled back showing the braided cover underneath and that seems to be where it is leaking. But, when I took the banjo bolt loose, there is a sealing washer under the bolt head and nothing between the banjo and the adjuster body. The adjuster body has an odd shaped recess in it. Anybody know what goes there? Thanks for any assistance. Link to comment
